Axle seals
Submitted: Thursday, Mar 05, 2009 at 21:54
The Yeti
Keep popping rear axle seal on my 100 series, breather checked and replaced, still blows seal after 20k's, mechanic has replaced 5 seals and is running out of ideas. Seal has been glued in and still blows. Has anyone got any ideas?
Reply By: Member - Ron M (NSW) - Thursday, Mar 05, 2009 at 22:24
Its your tires mate or your
wheels , Different size tires a
wheels will do it all the time .. check em..
352429
Reply By: PeterInSa - Thursday, Mar 05, 2009 at 23:00
Ron, what is the reason why Tyres/
wheels cause the problem, is it due to extra heat on the seal.
Yeti, I am assuming that you have the same
wheels and tyres all arouind at least the same
wheels and tyres on the back with the same tread wear. I use Nulon on my diffs have you tried that. Are you over filling the diff? Have you used an infra Red Temperature checker to check the wheel/bearing/brake temp. Jaycar sell them for about $40.
If Rons idea does not work out and you have tried all else I would replace the diff ( assuming your rear end has not been involved in an accident and its out of line) next step is to get rid of the vehicle. Also assuming its the seals adjacent to the
wheels and not the pinion seal.
My Cruiser is an old friend we have been thru so much together, it would be like putting down my wife's dog to sell it off. After failing every 20k's its not reliable and thats a 4Be must.
352442
Reply By: Ozhumvee - Friday, Mar 06, 2009 at 06:01
Is it the LH side? if so then the diff housing is probably bent, not an uncommon problem unfortunately.
If it is the RHS then the diff housing could still be bent but as the RHS is shorter and hence a bit stiffer it isn't as common.
It might also be a bent drive axle but the housing is more likely to bend than the actual axle.
352463
Follow Up By: Anthony (Vic) - Friday, Mar 06, 2009 at 11:51
A bent diff housing sounds like it would be very expensive to fix!
620719
Follow Up By: Ozhumvee - Friday, Mar 06, 2009 at 18:13
Visit any stealer in an area with lots of rough dirt roads (
Alice Springs, Nth Western WA etc) and they will tell you that later model cruisers suffer from bent and broken diff housings frequently.
620794
Reply By: Member - Tour Boy ( Bundy QLD) - Friday, Mar 06, 2009 at 13:27
I just replaced my front diff housing last firday as it was bent. My axle seal on the long side was blowing every 1000km. Bought a good housing from
Gold Coast 4wd wreckers for $385 and about $40 for courier to
Bundaberg. Easier to do rears than front but easy enough to do front in a day with new axle seals and do wheel bearing and seald as
well while apart. Queensland cruisers want $660 for a housing + freight
SHOP AROUND.
Mine was bent by 2º on one side and 1.5º on the other.
Dave
352540
Reply By: PeterInSa - Friday, Mar 06, 2009 at 15:28
Yeti,
I spoke to a friend who runs a big mechanical workshop and his comment was similar to the above either the axle is bent or the diff housing.
352560
Reply By: Al_&_Suzy - Tuesday, Mar 10, 2009 at 15:39
Hi Yeti,
I agree with the others about a bent diff housing. I had exactly the same issue with the front of my GU patrol and an axle specialist managed to bend it back to the correct position (cost about $900). It seems that the damage may have been done a couple of years ago when the car hit a washout hard on Fraser Island. I had been having wheel alignment and blown axle seal problems since then. Most tyre guys would not pick the issue. Good luck.
Regards,
Al
353240
