Another Ozi Explorer query??
Submitted: Friday, Mar 06, 2009 at 10:09
Member -Signman
If someone could direct me to a relevant post- or help me with this one.
I have loaded Ozi Ezplorer and my map collection onto my new lappy.
When I do a name search- the indicted location is
miles (or should I say kilometres) out. When I 'mouse' onto a place with a known lat/long- the indication in the top/left is also not reading correct.
In Configuration>System I have set WGS84
In the 'Map Window'I have selected WGS84
Obviously it is a datum/setup problem??
Over to the gurus !!
Reply By: Lex M (Brisbane) - Friday, Mar 06, 2009 at 10:16
The loaded map may not be WGS84
In the map window set it to "Datum of loaded map"
352487
Follow Up By: Member -Signman - Friday, Mar 06, 2009 at 10:20
Thanks mate- I'll give that a go..
Does Ozi 'read' the Datum of the loaded mao??
620693
Follow Up By: Richard Kovac - Saturday, Mar 07, 2009 at 00:51
What ever it was Signman, it should read if you can read this you are stupid.. or is that what LEX "M" would like us to think.. LOL
Richard
620843
Reply By: Member -Signman - Friday, Mar 06, 2009 at 10:21
Sorry---dunno what happened there !!
352488
Reply By: bgreeni - Friday, Mar 06, 2009 at 10:41
It certainly sounds like a map datum or projection problem.
Where did you get the maps and how did you create the .MAP files. If you are using scanned maps you have calibrated yourself that is probably the source of the problem.
Ozi reads the info it needs from the .MAP file and if that is incorrect you get the problem you have described. The selection in the "Map" window or at the top of the screen causes Ozi to reproject the map to the selected datum, but if the .MAP file is wrong this will not help as all ozi does is show position using the map to the selected datum/projection.
352493
Follow Up By: Member -Signman - Friday, Mar 06, 2009 at 10:46
The maps are proprietory like Hema, Rooftop etc..
NOT scanned and calibrated..
Thanks mate
620697
Reply By: Zebra400 - Friday, Mar 06, 2009 at 11:56
Not sure that this is a datum issue. Usually the datum error in Australia is around 200 metres because of the difference between new and old datums.
It sounds more like an error in your calibration fie.. If you are using the Natmaps, it is also possible you are using the old .map files.
352522
Reply By: Von Helga - Friday, Mar 06, 2009 at 14:41
Try the Ozi Help file
352555
Follow Up By: Member -Signman - Friday, Mar 06, 2009 at 14:45
Yup- been all thru the Ozi help file with no joy- maybe you could direct me to the relevant portion??
620756
Reply By: Member - Warfer (VIC) - Friday, Mar 06, 2009 at 15:37
Hiya Guys
Another quick question,I'm trying to load UBD version3 into Oziexplorer but it wont recognise the maps,What maps do you use for just around town ???
352563
Follow Up By: Zebra400 - Friday, Mar 06, 2009 at 16:22
Ver 3 works fine. There is a special program foe installing the map files. Let me know if you want it. It is a 1.5MB file.
It works differently to your other maps. You can copy the imae files into your Oziexplorer directory. Most likely you will find the images for UBD installed undet Program Files\UBD or similar.
620765
Follow Up By: Zebra400 - Friday, Mar 06, 2009 at 16:23
Sorry, that should say you cant copy your image files.
620766
Follow Up By: Member - Phil G (SA) - Friday, Mar 06, 2009 at 22:02
Warfer,
Go the Oziexplorer website; Australian Page; and it will give full instructions about making it work. Like Zebra says, you need to do a small download to get some working map files.
620828
Reply By: bgreeni - Friday, Mar 06, 2009 at 17:58
Something else to try.
Turn on
grid lines and see if they line up with the
grid on the map - always a good check on calibration
352597
Reply By: The Explorer - Friday, Mar 06, 2009 at 21:01
Hello
Hard to diagnose problem without being there and in absence of a tad more detail. Best bet is to name the specific map you are using and an example of a location you are noting as incorrect (i.e. correct co-ords and co-ords you are observing). What name search file are you using and where did you get it?
352634
Follow Up By: Member -Signman - Saturday, Mar 07, 2009 at 10:42
G'day Greg
I've had the ' name file' for a while now and just transferred it from puter to puter,,
Do you suggest a suitable file??
620856
Follow Up By: The Explorer - Saturday, Mar 07, 2009 at 15:45
There are some name search files here
Namesearch Files
In relation to your initial problem, see how you go. Maybe, as previously suggesed, name the actual map you are using and also coords of specific location (wrong and right coords you are comparing)
620894
