100 LC dual batteries
Submitted: Friday, Mar 06, 2009 at 17:28
ThreadID: 66571 Views:2660 Replies:4 FollowUps:11
one of the batteries has finally carked it on the 2006 TD
i am now going to upgrade to a dual system.
does one need to get (or should get) larger battery carriers or will the NZ70 (if thats correct) fit the existing?...does it fit?...what does fit if it doesnt
Reply By: Member - Alastair D (NSW) - Friday, Mar 06, 2009 at 18:03
No 1,
Yes an N70ZZ will fit in the existing battery trays.
In my LC100TD I have a Bosch cranker in the LHS and an AGM DC on the RHS. The cranker does the obvious starting duties and runs the winch. The deep cycle runs the fridge etc. It is separated by a smart switch and has run without problem for a couple of years. The isolating is very easy due to the way Toyota have made the loom.
Being at the front of the vehicle they run much cooler than where the second battery is near the firewall as in my troopy. This is good especially for the AGM DC.
alastair
AnswerID: 352598
Follow Up By: Member No 1- Friday, Mar 06, 2009 at 18:09
mmm no they dont
pulled the one out of camper and battery holder needs some adjustment...now i need to get the angle grinder out , then the welder, then see if it doesnt fit, then back to drawing board, and so the cycle continues...lol
but one thing I have noticed is that a longer battery carrier can be accomodated
does any one know if they are available and what is biggest battery that one can get into it..that space?
FollowupID: 620793
Follow Up By: Member - Alastair D (NSW) - Saturday, Mar 07, 2009 at 11:36
No 1
I had no problem with mine. Both N70zz btteries fitted in without alteration. I think your battery out of the CT must not be a standard size.
Photos of mine to prove the point.
Image Could Not Be Found
alastair
FollowupID: 620861
Follow Up By: Member No 1- Sunday, Mar 08, 2009 at 13:03
maybe it isnt an NZ70 or what ever...i will go check
but the case is definitely 225 high not including the terminals
FollowupID: 621094
Reply By: chisel - Friday, Mar 06, 2009 at 18:12
Might helphttp://neuralfibre.com/paul/4wd/fullriver-120ah-agm-into-100-series-cruiser
He's on lcool
AnswerID: 352599
Reply By: Member - Phil G (SA) - Friday, Mar 06, 2009 at 18:41
MN1,
The casings of batteries are very strong, so there is no problem with having a battery overhang by a couple of inches. You will find that some Toyotas came from the factory like this - 90series TD Prados for example.
N70 is a 12 inch long battery. Next size up is a 13inch battery (344mm long) and they will certainly fit on the drivers side of your 100series TD.
Most people I know isolate the dual batteries, leaving the passengers side battery as the cranker. It is an easy job :-)))
AnswerID: 352600
Follow Up By: Member No 1- Friday, Mar 06, 2009 at 21:01
the carrier tray/s on this has the edges rounded upwards and are plastic......lol
wouldnt like to see the battery overhanging on plastic junk
FollowupID: 620818
Follow Up By: Member - Phil G (SA) - Friday, Mar 06, 2009 at 21:17
Hehe.........The tray is there for "cosmetic" reasons only and to collect any battery spills. Your new battery can overhang without a problem. The 90series Prados even had the plastic tray overhanging!!
FollowupID: 620821
Reply By: Muddie - Friday, Mar 06, 2009 at 19:50
Have a look at what I did on the Lcool forum.
www.lcool.org/forum/viewtopic.php?t=140&postdays=0&postorder=asc&start=0
The bigger batteries N70ZZ fit, just, into the standard holders.
regards David
AnswerID: 352617
Follow Up By: Member No 1- Friday, Mar 06, 2009 at 20:59
but how high are the batteries you have
the one I took out of the camper is higher than the existing (220mm old at 200mm) and the existing clamp (the one that goes across the top) wont fit
FollowupID: 620817
Follow Up By: Muddie - Friday, Mar 06, 2009 at 22:17
I will check in the morning but found these sizes on internet, 306 long x 173 wide X 225 high for the Delkor Puma 27HR 710CCA I use as a starter.
regards David
FollowupID: 620833
Follow Up By: Muddie - Saturday, Mar 07, 2009 at 09:15
The above is true, just checked with a tape, the battery case is 200mm high the terminals take it to 225, the clamps fit well as you can see in the pic.
FollowupID: 620849
Follow Up By: Brooka27 - Saturday, Mar 07, 2009 at 16:08
David what do you have mounted in the top right hand corner of the pic shown above ?
FollowupID: 620897
Follow Up By: Member No 1- Sunday, Mar 08, 2009 at 13:06
thanks David
as i said above maybe mine isnt a NZ70....but it wont fit as i have already tried and thats when i measured it at 225 for the case +
terminals
off to check out the details
FollowupID: 621096
Follow Up By: Muddie - Sunday, Mar 08, 2009 at 20:56
Brooka27 : Its a Warn 12 cfm compressor mounted side on, I run 35"s and the old ARB took forever.
FollowupID: 621153
