Landcruiser 12HT stops
Submitted: Saturday, Mar 07, 2009 at 01:03
Pelesino
any experts out there, my 12HT cruiser likes to stop when idling on a step
hill for a few minutes. Once moved to flat surface its Ok. If I keep reving it gets rough but does not stall, but if left to idle then it stops.
I though it could be a dirty
fuel tank ?
Any ideas ?
Reply By: ross - Saturday, Mar 07, 2009 at 08:30
I doubt its dirty
fuel as you have a good filtration system and if it was the
fuel ,it would do it all the time.
My guess is it could be the
fuel feed pump attached to the side of the injection pump.(its connected to the priming pump)
Parking on a
hill might be too much for the feed pump at idle.
A
fuel injection
shop could remove it(or its a simple job to remove yourself) and test the pumping pressure
352679
Reply By: Member - Phil G (SA) - Saturday, Mar 07, 2009 at 09:05
May be the low oil pressure cutout?
352683
Follow Up By: ross - Saturday, Mar 07, 2009 at 12:24
There a stop lever on the pump,I was wondering if its cutting the
fuel to the pump because its out of adjustment/loose.
620869
Reply By: Member - DOZER- Saturday, Mar 07, 2009 at 13:32
Its
fuel related due to stopping on
hill...there is a restriction in the
tank or pump or filters, or the lift pump is weak or a combo of all....add
hill and it wont suck enough to run properly or keeprunning at idle...start with the
fuel filter, if no change the in-
tank filter, then the
fuel pump inlet filter and if all that doesnt solve it, the lift pump.
Andrew
352720
Reply By: philldeb - Saturday, Mar 07, 2009 at 13:43
Could be low oil pressure at idle. Kick up your idle screw 100 rpm to see wot it dose then
352722
