water works problem-'98 diesel Triton 4x4
Submitted: Saturday, Mar 07, 2009 at 13:27
AdlelaideGeorge
I've noticed coolant dripping from the bash plate onto the garage floor. Looking up from under the car to the right side of the engine (under the alternator as you look up from underneath) I can see a trail of coolant (apparently) coming from a bolt that I think is a
water pump bolt-I removed that bolt but the
water definitely isn't coming from there. The
water seem to be appearing from nowhere-like a spring from a rock! No matter how hard I try I can't pinpoint the exact spot that the leak is coming from-it's not spraying from a hose and it doesn't appear to coming from the
water pump housing behind the fan. Any ideas? It's a very slow leak.
Also-has anybody had any
water pump or similar work done on a diesel in
Adelaide lately that they have been happy with-any recommendations for a competent mechanic?????
Reply By: Member - Mark G Gulmarrad - Saturday, Mar 07, 2009 at 13:48
AdelaideGeorge
where is your coolant over flow hose?
it isnt coming out of there is it?
just a thought,cheers.
352723
Follow Up By: AdlelaideGeorge - Saturday, Mar 07, 2009 at 13:53
Hi Mark - no, the
overflow hose is the other side of the engine bay and it's not coming from there. Good idea though - thanks
George
620876
Follow Up By: Member - Damien L (Cairns) - Saturday, Mar 07, 2009 at 14:16
Not coming from the aircon???
620878
Reply By: Member - Tony B (Malanda FNQ) - Saturday, Mar 07, 2009 at 17:11
Funny things
Water pumps. They are not always easy to pick if they are faulty. Best bet it to get the coolant system pressure tested. When under pressure the leak will be more apparent. Sometimes you have to also have the motor running while under pressure before the fault is found. A pressure test will find the fault though and some
places may not even charge for this, we never used to. Cheers Tony
352771
Follow Up By: Member - Tony B (Malanda FNQ) - Saturday, Mar 07, 2009 at 17:17
P/S Also the
water pump should have a bleed hole (tell tale) between the fan and the bearing. When the bearing starts to go it usually starts bleeding from this outlet.
620913
Follow Up By: AdlelaideGeorge - Saturday, Mar 07, 2009 at 20:08
Thanks Tony - yes I'd read about a bleed hole in the Gregorys - I think that's what it's ultimately going to prove to be - the
water pump seal. It's just so difficult to see that's where it's coming from.
I'll get it pressure tested.
George
620951
Follow Up By:- Saturday, Mar 07, 2009 at 21:24
AdlelaideGeorge what workshop manual are you using as I have the same car?
620979
Follow Up By: AdlelaideGeorge - Sunday, Mar 08, 2009 at 14:38
Hi - I've got the Haynes (did i say gregorys?) Mitsubishi Pajero 1983-1996 Pajero Series NA thru NJ.
My Triton is not that year but I have found virtually everyrhing I have needed for my diesel Triton is the same - brakes, gearbox and transfer case lubrication details etc etc. I have never had to strip the actual engine down but I would think it's the same the 2.8 normally aspirated motor is covered in the manual-it's refered to as a 4M40 motor and that's what my Triton is.
I couldn't find one for a my Triton
George
621112
