R/ hand positive AGM battery
Submitted: Sunday, Mar 08, 2009 at 22:11
Featherfoot
Hi all,
I was wondering if anyone knows of an AGM deep cycle 100 amp hr (or so) right hand positive terminal battery. IE with terminals closest to you pos terminal is on the r/hand side. N70 ZZ size or smaller.
Gary
Reply By: Robert H (SEQ)(aka zuksctr) - Sunday, Mar 08, 2009 at 22:16
Featherfoot, trick question, i will go with turn it around to suit.
Cheers Bob.
352989
Follow Up By: stephen looking - Sunday, Mar 08, 2009 at 22:27
Rob i think FF is talking about the depth of the battery, and the terminals on one side i think i've explained myself :)
Cheers......Steve
621173
Follow Up By: Featherfoot - Sunday, Mar 08, 2009 at 22:27
Sorry Robert ,wrong answer. Has to be RHP
Gary
621174
Follow Up By: stephen looking - Sunday, Mar 08, 2009 at 22:33
Featherfoot i have a full river 100ah its on the left, do right handed batteries work better or some thing :)
cheers.......Steve
621177
Follow Up By: Featherfoot - Sunday, Mar 08, 2009 at 22:55
Not that I know of Steve, just suits my application
Cheers......Gary
621180
Reply By: Bonz (Vic) - Thoughtfully- Sunday, Mar 08, 2009 at 22:43
you need a N 70 ZZL I do believe, same as the N70 ZZ but terminals reversed
352998
Follow Up By: Featherfoot - Sunday, Mar 08, 2009 at 22:58
Hi Bonz,
Do you know of an AGM in that configuration as I believe they are hard if not impossible to get.
Gary
621181
Follow Up By: Rossc0 - Sunday, Mar 08, 2009 at 23:26
I know they're not AGM but Optima are mostly with the terminals in the centre of the battery so can be mounted either way.
Hi have D51T as crank and D34 as auxiliary.
Ross
621187
Follow Up By: Featherfoot - Sunday, Mar 08, 2009 at 23:33
Thanks for that
Ross.
Gary
621188
Reply By: Axel [ the real one ] - Monday, Mar 09, 2009 at 08:52
Terminal on wrong side of battery = lengthen the cable/s and save the headache.
353024
Reply By: Member - Graham H (QLD) - Monday, Mar 09, 2009 at 10:45
Seems to me the obvious place to ask this is at your local Battery World
shop
I have two Yaeusu Hybrids in my croozer and one has the termials opposite to the other. That is the negs are on the mudguard end of the battery.
Probably other types are available as
Or do you want both terminals at the same end but mirror imaged.
353038
