Stop rusting bolts
Submitted: Wednesday, Mar 11, 2009 at 00:39
timglobal
Hi all,
As the topic says, I have some bolts that I've used to attach recovery points onto my front bar. They are steel, so have already got a slight
orange tinge. What should I paint (or ideally spray) them with to stop this now and in the future?
Hammerite?
Something else?
Thanks,
Tim
Reply By: Member - Willie , Sydney. - Wednesday, Mar 11, 2009 at 08:04
Hi Tim,
If you are really keen, you can put the bolts in the oven. After heating them up, coat them in lanolin and let them cool down. Wipe off excess. ( use pure lanolin not a spray mixture )
I have been told that the lanolin penetrates a couple of microns into the metal - I know it is a brilliant rust inhibitor. We used this system on the exposed moving parts of our fishing reels that were in constant contact with salt
water.
Willie
353351
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Mar 11, 2009 at 08:48
2nd that.
I now use lanolin grease on every bolt for rust and easy removal.
621497
Reply By: Member - Peter R (QLD) - Wednesday, Mar 11, 2009 at 09:57
Me too .Use Lanotec grease on boat trailer. It stops the rust from progressing ,
Pedro
353370
Reply By: Sigmund - Wednesday, Mar 11, 2009 at 12:54
You already have a bit of rust so another way to go is to paint on some rust converter and then finish with paint.
I use lanolin based spray to stop cast iron from rusting but it needs regular applications.
353403
Reply By: Bob - Wednesday, Mar 11, 2009 at 13:51
It must work
well, I,ve never seen a rusty sheep and they are out in all wethers.
353418
Follow Up By: Member - Willie , Sydney. - Wednesday, Mar 11, 2009 at 14:24
Maybe they are just pulling the wool over your eyes Bob. Ewe want to watch them.
Willie.
621558
Reply By: Member - Bucky, the "Mexican"- Friday, Mar 13, 2009 at 04:34
Lanotec or Inox with lanolin called lanox, are both brilliant
Bucky
353726
