x jack
Submitted: Friday, Mar 13, 2009 at 07:33
dustmike12
hi
has anyone used the x jack . cant decide between the jack & the x tracks to purchase.
mike
Reply By: Member - Graham H (QLD) - Friday, Mar 13, 2009 at 08:59
Maybe you will need the jack to allow you to get the tracks underneath
353746
Reply By: Anthony (Vic) - Friday, Mar 13, 2009 at 15:02
I have read on this
forum that the use of exhaust jacks on turbo engines may cause problem due to turbos not liking the exhaust back pressure created by the jack.
If this is true and your 4wd is a turbo diesel, then maybe max trak or similar is better for you.
353808
Follow Up By: Member - Kiwi Kia - Friday, Mar 13, 2009 at 15:12
If you have read that then you should also have read just as many people saying that it is a load of ..........
621935
Follow Up By: Anthony (Vic) - Friday, Mar 13, 2009 at 15:44
no, .... but I have now.
621937
Reply By: neilbis - Tuesday, Mar 17, 2009 at 00:53
I have one and i find its great on sand as everyone reports......on mud mixed results (just make sure no ones anywere near under the car as it will slip). In mud we use in ontop of the spare tyre.
In saying that, i let a mate use it on his car and he somehow snagged the compressor valve making a hole....i havent even tried fixing it yet. I would probably prefer getting a bag with only the exhaust option...less snag points.
354457
Reply By: dustmike12 - Tuesday, Mar 17, 2009 at 21:44
thanks mate good bit of info
354610
