1992 Pajero TD Crankshaft Seals
Submitted: Thursday, Mar 19, 2009 at 19:30
ThreadID: 66987 Views:2121 Replies:2 FollowUps:4
Recently (18,000km ago) had a recon motor installed. 2.5 Turbo Diesel. After 17,000, crankshaft seals both went along with leaks from the riocker cover gasket. Oil disappeared rapidly and big ends now stuffed! Currently having 'discussions' with the dealer who installed the motor.
Anyone else had issues with these seals failing after such low mileage?
Reply By: toyocrusa - Thursday, Mar 19, 2009 at 19:48
Hi Phil. Your engine sump holds around 5 litres of oil. Provided it was full before hand then there should have been huge pools of oil on the floor/ground for the seals to leak that much oil. It is possible something has happened inside the engine to cause it to use(burn) oil which would make the oil dissappear more quickly.I think I would contact a motoring organisation(MTA or similar) with the veiw to getting an engineer to inspect the engine and write you up a report. Regards,Bob.
AnswerID: 354977
Follow Up By: Phil Angel - Saturday, Mar 21, 2009 at 11:54
Thanks for the reply. I've been in touch with the Department of Consumer Affairs but they need the engine stripped down before they can comment. (At a cost of about $2,000 which I have to cover). The vehicle was being driven along a freeway when it all went to s**t. No smoking beforehand. No oil pressure warning light! Dealer replaced seals before sounding out engine. Now he wants $1,300 for that work, even though the engine's stuffed!
Motor was warranted for 80,000km with services at 5,000km. Unfortunately there were 8,000km since last service. I'd have thought 10,000km was the standard. Dealer maintains warranty voided!
FollowupID: 623332
Follow Up By: toyocrusa - Saturday, Mar 21, 2009 at 17:55
Hi Phil. i am a motor mechanic in NSW. I had a customer have a similar engine failure in a small petrol engined car a few years ago. The person was in the NRMA so we advised him to contact their legal department. They in turn asked me to dismantle the engine so that an engineer contracted by them could inspect it and make a report which duly happened. Armed with that report the legal dept. then went to fair trading and requested a hearing which was scheduled to the near future. Before that hearing was held the engine builder agreed to a settlement with the owner which left him slightly out of pocket but much better off than to start with. Although you are 3000Km over the service shedule I fail to see how this would contibute to a major failure. You still may have to pay for the dismantling ($2000 sounds outragious by the way. I'm sure it should be done much less than that, my labour is $66/hr. even at 15 hrs that still around $1000) but if these guys are replacing crankshaft seals in a damaged engine I feel they should not be working in the motor trade.Contact your State motoring organisation and /or MTA and keep hounding. Sounds like so far you have been hard done by. Bob.
FollowupID: 623382
Follow Up By: Phil Angel - Monday, Mar 23, 2009 at 17:33
Thanks Bob. I'm trying all the avenues I can think of short of using lawyers!
I'm thinking the motor was not of merchantable quality.
FollowupID: 623705
Reply By: Member - Oldplodder (QLD) - Friday, Mar 20, 2009 at 09:13
No porblems here with the 2.8. (jus the keyboard).
Engine rebuild about 25,000k ago and going well.
Sorry to hear of your problem.
Have you tried the pajero forum at the Victorian 4wd club?
pajero forum
AnswerID: 355081
Follow Up By: Phil Angel - Saturday, Mar 21, 2009 at 12:10
Thanks for that. I'll give it a go.
FollowupID: 623337
