trans axle code landcruiser
Submitted: Friday, Mar 20, 2009 at 09:28
qubert
hello i am trying to find out what diff rratio my ute is . but the trans axle code is R151F A02B. can anyone tell me what this means .
Reply By: Mr Pointyhead - Friday, Mar 20, 2009 at 10:03
Landcruisers have gearboxes not transaxles ...
R151F is the gearbox model. Others found on 'cruisers are H151 and H150, the difference being the ratios
355092
Follow Up By: ross - Friday, Mar 20, 2009 at 10:31
They dont have a transaxle,but they do have a trans/axle code on the firewall
The AO2B is the t/case/diff I think,my brothers Prado had A02A.
The difference is whether it has a centre diff lock or whatever it is called
Is this vehicle a Prado or full size landcruiser?
623148
Reply By: Member - Phil G (SA) - Friday, Mar 20, 2009 at 12:33
You have a HZJ79 ute and they run a 4.3 diff ratio.
355124
Follow Up By: qubert - Friday, Mar 20, 2009 at 12:52
thanks
623179
Reply By: Big Woody - Friday, Mar 20, 2009 at 20:48
Hi qubert,
this site will usually answer all of your questions.
Axle Codes
Based on the code you have provided something isn't working. Are you sure there is not another axle code somewhere on the plate.
I have used this site several times on landcruisers of all ages and the tables have worked every time.
BW
355208
