Domestic RM2350 question?
Submitted: Saturday, Mar 21, 2009 at 17:06
JAZZY
Hi there
Purchased a jayco dove 8 months ago (second hand) 2006 model, and have not used the fridge on gas yet, tried it this arvo, and there was a fair bit of heat coming out the vent at the back of the fridge (from the outside of the van), so turned it off.
It lit ok, no problems, but I hadnt turned the fridge on at all (240v) first as advised on here, so would there be a fair bit of heat coming from the flue because it had to work hard to cool the fridge down?
Domestic RM2350 3 way fridge
Reply By: Stu-k - Saturday, Mar 21, 2009 at 17:10
Yep they do throw out a bit of heat when you crank them up(temp down)
Try turn the temp up a bit they seem to run better
355351
Follow Up By: JAZZY - Saturday, Mar 21, 2009 at 17:20
Thanks for that Stu,
And how long should it take for the fridge to start cooling down? I know with 240v it takes ages - up to 2 hours, but then runs fine, is gas the same?
623378
Reply By: JAZZY - Saturday, Mar 21, 2009 at 17:13
355352
Follow Up By: Stu-k - Saturday, Mar 21, 2009 at 20:13
There better on gas,maybe 40mins or so and the walls inside the fridge will feel cool. Forgot to mention, dont forget to set it up level
623399
