edic help
Submitted: Saturday, Mar 21, 2009 at 18:56
ThreadID: 67050 Views:2528 Replies:5 FollowUps:2
need help! when my 85 model cruiser is under load, any thing over 1000 rpm the edic motor slowely closes then shuts off fuel for a second then runs. it is intermitant about every 10 seconds and quicker with electrical items on. can someone help its doing my head in
Reply By: qubert - Saturday, Mar 21, 2009 at 21:02
is your engine oil pressure ok. if you have low or no oil pressure it will shut down
AnswerID: 355378
Reply By: dozza - Saturday, Mar 21, 2009 at 23:20
oil pressure is below half but is not effecting engine performance, it looks to be more of an electrical fault the solenoid for the fuel shut of it closeing every 10 seconds when the edic moter kreeps forward cousing it to shut of the fuel and make the engine cough
AnswerID: 355392
Follow Up By: V8 Troopie - Sunday, Mar 22, 2009 at 00:40
You should also check the oil pressure connection, perhaps it has come off. From memory, its on the same side and a little above the edic motor.
There is a timing device that does the 10 sec thing, timer is behind the glove box. I used this function as a theft deterrent, secret switch to the oil pressure sensor. Thief gets 10 sec running after jump starting it, has to jump start it again and again and, hopefully gives up down the road:-;
FollowupID: 623426
Reply By: Wayne's 60 - Sunday, Mar 22, 2009 at 00:32
Hi Dozza,
Will be a electrical/power supply problem. Check that your battery/batteries are all good and your alternator has 13.8v output and that your regulator has not had a spit. There was a post in recent times where this was discussed.
Had a similar problem with my 60, when the electrical system was under load and the EDIC would move to shut the engine down and the problem became worse with a greater electical system loading ....... ie spot lights .. fridge ... radios .......
Hope this helps.
Wayne.
AnswerID: 355401
Follow Up By: Wayne's 60 - Sunday, Mar 22, 2009 at 00:36
PS
Low oil level will activate the low pressure cut off switch, which may appear to behave in a similar manner to what you have described.
Wayne.
FollowupID: 623425
Reply By: Spook - Sunday, Mar 22, 2009 at 16:55
Hi dozza,
I had exactly the same problem with my 60 series, it turned out to be the Fusible link near the battery. The Auto elec said it was not an uncommon problem. I had my doubts but when he replaced it problems were gone.
Hope this helps
AnswerID: 355470
Reply By: dozza - Sunday, Mar 22, 2009 at 19:32
thanks heaps for your help guys, hope one day i can help u allso
AnswerID: 355494
