sunraysia offset
Submitted: Sunday, Mar 22, 2009 at 18:17
Member - John and Val W (ACT)
Does anyone know the offset of a sunraysia rim that came off a 60 series landcruiser? Would it be suitable for a 75 series Troopy?
| J and V
- Albert Einstein
Reply By: Member - Graham H (QLD) - Sunday, Mar 22, 2009 at 19:02
Try it and see.
There is a tyre comparator on here or you could play with this one as it shows you how to measure them
http://www.rims-n-tires.com/rt_specs.jsp
355491
Follow Up By: Member - John and Val W (ACT) - Sunday, Mar 22, 2009 at 19:24
Thanks Graham,
I'd try it if I could, trouble is the vehicle is 300 km away from the
wheels! I'll check out the site you mention.
| J and V
- Albert Einstein
623537
Reply By: Willem - Monday, Mar 23, 2009 at 07:28
Hi JOhn
AFAIK Sunraysia
wheels are made to fit all earlier model 6stud Toyota LC's and Nissan Patrols. You should be safe. 2nd hand ones shouldn't be worth more that $40 each
355574
Reply By: Member - Phil G (SA) - Tuesday, Mar 24, 2009 at 21:38
Gday John,
All 40, 60 and 75 series are the same offset.
80 and 95 series are different - they have too much backspacing.
355964
Follow Up By: Member - John and Val W (ACT) - Wednesday, Mar 25, 2009 at 07:34
Thank you Willem and Phil. That's good info. I have been stuck before trying to fit a "Landcruiser" wheel to my 75 series Landcruiser. Fits yes, but the wheel wont turn thanks to wrong backspacing!
| J and V
- Albert Einstein
624015
