Hilux Sitting Around At Home Question (non use)
Submitted: Monday, Mar 23, 2009 at 23:10
Member - Warfer (VIC)
Recently Ive been running around in my Berlina and the Hilux has been sitting at home not even started for weeks on end...What would you suggest i do, say its OK for a couple of weeks on end or lets say run it 20kms a week minimum..
Its kept under my carport..What do you guys do.
Suggestions appreciated..
Reply By: Lex M (Brisbane) - Monday, Mar 23, 2009 at 23:16
And the question is..........
355792
Reply By: Member - Royce- Monday, Mar 23, 2009 at 23:29
Give it to me!
355793
Follow Up By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:32
Good try Royce lol,I know you would love to get your mitts on it up in the
latrobe hills...lol
623896
Reply By: Member - Dunworkin (WA) - Tuesday, Mar 24, 2009 at 01:03
Hi Warfer, when our daughter was working up North she would leave her Navara here and we would take it for a run over to the shops about once every one - two weeks, seemed OK at that, the battery was the biggest problem.
Deanna
355803
Follow Up By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:38
Hiya Mate
Yeah the batts are the main issue because they have been great and dont want it to change...
623900
Reply By: Axel [ the real one ] - Tuesday, Mar 24, 2009 at 08:59
6 mth trip last yr , parked wifes KiaRio in under house garage , disconected battery and covered vehicle with old blankets , upon return connected battery , reset clock and radio stations , turned key and drive , no worries,
355824
Follow Up By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:40
***disconected battery ****
Will keep that one in mind..
cheers axel
623902
Reply By: Member - Troll 81 (QLD) - Tuesday, Mar 24, 2009 at 10:04
I went OS for 12 months a couple of years ago and go someone to drive my car every 2 weeks for at least 30 min and everything was fine when I got back.
355836
Reply By: austastar - Tuesday, Mar 24, 2009 at 11:08
Clip one of those $20 LED volt meters across the battery and leave it where you can see it easily.
If the voltage gets down, charge it before trying to start it.
Better (but more expensive) is to put it on a smart charger that will maintain the battery.
355848
Follow Up By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:44
Hiya austastar
I have the IBS system by TJM that shows the voltage of each batt,i never thought (idiot) to keep an eye using it while sitting there,only when i go away lol
IBS
Image Could Not Be Found
623904
Reply By: Member - Kiwi Kia - Tuesday, Mar 24, 2009 at 14:57
If you are going to leave it for an extended period then it may be worth while changing the oil first (if it has many kms from last change). Sludgy oil with contaminates and moisture can eat big end shells.
355877
Reply By: Blaze (Berri) - Tuesday, Mar 24, 2009 at 16:03
Being thats its only a Yota Mate, maybe wind down the windows and use it as a chook house LOL.. Only Jokin..
I run
mine a minimum of about 20k's a fortnight, all in the one run, so oil etc gets warm.
355890
Follow Up By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:37
People hav been known to hav chooks thrown in there tent/swag in the middle of the night
camping peacefully down by the
Goulburn River...lol
Yeah i reckon 20k a fortnight sounds the go for the batts and engine..
623899
Follow Up By: Blaze (Berri) - Tuesday, Mar 24, 2009 at 17:33
Wow Glad I'm in my camper when where over that way LOL.
Mind you roast chook the following night doesn't sound bad.
623914
Reply By: get outmore - Tuesday, Mar 24, 2009 at 16:12
working FIFO I can garantee you leaving a vehicle parked up for extended perods regulary does nothing except give them a rest
355893
Reply By: Member - Warfer (VIC) - Tuesday, Mar 24, 2009 at 16:31
Thanks Guys some good ideas,When i had the Holden sitting around for 3 months (battery topped up 1 month later)...It ran great for 3 weeks and then it crapped out (batt) one cell was stuffed,also the cruise stopped working,now how does that happen from non use lol,it was a bracket apparently..Although battery was replaced under warranty...Never owned a Diesel before so hence the question...
355898
