towing disabled cars
Submitted: Friday, Mar 27, 2009 at 22:23
kcandco
I have heard it is now illegal to tow a vehicle with a tow rope. And that a rigid towing bar must now be used. Has anyone made one up? I am in Qld.
regards Kc
Reply By: DaveO*ST-R - Friday, Mar 27, 2009 at 22:51
KC
Victoria Road Rules certainly allow a vehicle to be towed by another via a tow rope, chain or strap etc, even if the vehicle is unregistered. (must be safe to use on a road though) There are specific requirements, such as the driver of the towed vehicle must be licenced to drive it in the first place and must be able to have control over the steering and braking. Tow ropes etc cannot exceed 4 metres.
A quick search of Queensland Road Rules brought this up:
Towing another vehicle:
"When towing another vehicle by means of an “A” frame, rigid drawbar or rope, the drivers of the towing and towed vehicles must hold a current driver’s licence that includes the classes of vehicles being utilised. An “A” frame may also be used to tow another vehicle that has no driver if the specific conditions on the "A" frame towing page are met in addition to the general requirements for drivers and towing vehicles described so far."
Also mentions "If you are towing a car with a towline, the towline must not be more than 4 m long."
Dave
356669
Follow Up By: Member - Doug T (NT) - Friday, Mar 27, 2009 at 23:18
Dave
I have been thinking about making a "Stiff Bar" (truckies term) with a ball coupling on one end ,basicly it would look like a V shape collapsible A-Frame that could be fixed/bolted to the tow eyelets on the bullbar , so instead of pulling a car you could push it....providing that car had a towbar, it could also be used to pull as
well,
Or just the straight bar would work to .
Image Could Not Be Found
624728
Follow Up By: Skippy In The GU - Friday, Mar 27, 2009 at 23:30
Does the towed vehicle need brakes like trailer do if over 750kgs
Here in SA a stiff bar can only be used to safely tow a vehicle
(mainly trucks and buses ) to the next
Truck Stop /
Rest Area for safetly reasons
624731
Follow Up By: Member - Doug T (NT) - Friday, Mar 27, 2009 at 23:34
Skippy
This idea of
mine would be the same as for trucks being pushed/pulled, there would be someone in it, would you tow a car on a rope without anyone in it...???
I'm not reffering to A-Framing as like a Motor home towing a small car.
624732
Follow Up By: Member - Malcolm (Townsville) - Friday, Mar 27, 2009 at 23:49
I remember in the early 60's the army had 'A' frames for the Mk 3's. One solid bar and another hinged to form the 'A'. Conditions (at that time) were that a driver had to be sitting in the towed vehicle. I can remember doing it once. Damn hard to resist trying to steer the vehicle. The 'Ackerman's Principle' looked after all the steering automatically and the towed vehicle just followed the vehicle in front.
About the same time I went out to
Olive Downs Stn on holidays and welded one up for them so the truck, loaded with
hay, could hook on the landrover and take out to the stock.
Park the truck and drive back in the towed vehicle.
M
624733
Follow Up By: Member - Warfer (VIC) - Saturday, Mar 28, 2009 at 01:47
Hiya Dave
I was told by a mechanic quite recently (just out of conversation) that it was Illegal to tow a vehicle with rope in Victoria...
A lot of mixed messages getting about..
624755
Follow Up By: DaveO*ST-R - Saturday, Mar 28, 2009 at 07:40
Doug
Interesting concept, but the rules say you can tow, no mention whatsoever about pushing !! Not ever having tried it before, I can only imagine the chaos out there (if it was permitted) trying to work out the steering processes involved.
Dave
624768
Follow Up By: Member - Doug T (NT) - Saturday, Mar 28, 2009 at 08:50
Dave
The steering process of the vehicle being pushed is performed by a human sitting in the drivers
seat with his hands on the steering wheel, this concept could be adapted for very sticky situations by connecting 3 or 4 4x4s together, as the roadtrains did many years ago in NQ , although these days that practice is not allowed on the roads because of the damage caused to the roads, I've seen photo's from the 50s amd 60s of up to 4 roadtrains push/pulling through creeks between
Winton and
Cloncurry,
624774
Follow Up By: Shaver - Sunday, Mar 29, 2009 at 08:25
Doug.
As a former Army Recy Mech from the 60's era, the towing thing you want to make up was called a "Hollibone". "A Frames" were used for lift towing & the other Hollies for flat towing without anyone in the towed vehicle. Safety chains were used between vehicles. In the 6 years I was in I used the Hollies once on a Landrover which was towed by a "Dinky Toy" (another Landrover Recy Vehicle). I never trusted the Hollibone setup on heavy tows & always went for a partial lift tow on a "A" Frame.
624883
Reply By: Geoff (Newcastle, NSW) - Saturday, Mar 28, 2009 at 00:00
Coupling a pair of 4wd's via an A-Frame makes one formidable off road vehicle in mud, snow and sand.
Not so good on big snotty rutted hills though!
With 8
wheels and 4 drive axles there'll almost always be something with a bit of grip!
Similar formula to the one Caterpillar and Terex scrapers use when coupled together.
Geoff
| Geoff,
356681
Follow Up By: Ozhumvee - Saturday, Mar 28, 2009 at 07:42
I can remember doing that with three vehicles back in the 70's to get them up a very wet
hill on the Carters Brush track. Very scary when you are in the middle and all you can do is brake and accelerate.
But like you said something always had traction and it kept going. Not many
winches around in those days and most 4wd's were shortys.
624769
Reply By: DaveO*ST-R - Saturday, Mar 28, 2009 at 07:07
Warfer,
That's half the battle sometimes with a lot of misinformation floating around. Quite legal to tow another vehicle in Victoria by rope etc, provided the nominated conditions are met. The relevant Road Rule No. is 295.
http://www.vicroads.vic.gov.au/NR/rdonlyres/4C0E08C5-D7C1-4301-AEFA-3A984D7C2761/0/part_18.pdf
Also - An excerpt from the Vic Roads website - relating to moving an unregistered vehicle from place to place:
"Tow behind a registered vehicle:
You can tow the unregistered vehicle behind a registered vehicle. Road Rules Victoria 1999 (no. 295) apply when towing. They are:
* you must safely control the towed vehicle (you can be on a probationary licence)
* the brakes on the towed vehicle must be working when you are using rope, chain or wire
* the maximum space between the vehicles is 4 metres (if either vehicle is a motor cycle, the maximum is 2.5 metres)
* you must display a flag (minimum 30cm square) attached to the rope, chain or wire."
Regards,
Dave
356688
Follow Up By: Member - Warfer (VIC) - Saturday, Mar 28, 2009 at 23:00
Thanks a lot Dave for the extra info to mate,Not that i plan on doing it myself, R.A.C.V. But someone may not be in it and need my help and I'd feel comfortable doing it knowing the correct rules. !
624864
Reply By: Member - JohnR (Vic) - Saturday, Mar 28, 2009 at 09:52
Not completely off topic to towing, did you see the Google Street Level car being pulled through by the Patrol
Bourke Wilcannia Road? It took me a couple of minutes to find it, but a Patrol with a
snorkel, roof top tent and an
HF radio pulling the car along a sticky section. Person off to the side with a brownie
orange jumper
356698
Follow Up By: Member - JohnR (Vic) - Saturday, Mar 28, 2009 at 10:07
[img]
[/img]
624783
Reply By: ross - Saturday, Mar 28, 2009 at 09:56
Its ok to tow in WA but Im sure the towed vehicle has to be registered. I dont think temporary movement permits apply.
356700
Reply By: Member - Smiley Bill - Saturday, Mar 28, 2009 at 18:46
Hi kcandco,
Forget about pushing vehicles, this is only done in specific circumstances.
Tow ropes are fine as
well as solid frames but you would have to check with your state traffic authorities for the specifics as all the states have minor differences.
Snatch straps are only used to get bogged vehicles out of trouble, not tow anything further than necessary.
SB
356742
Follow Up By: D200Dug- Saturday, Mar 28, 2009 at 22:28
Back in the good old days ..................
On occasion I found it useful to push other vehicles either to jump start them or to get them out of bogs when you could not get a tow vehicle past the bogged vehicle.
I would strap my bull bag firmly to the bull bar to provide a cushion between the vehicles and just nudge up behind the car.
It worked
well quite a few times.
624859
Reply By: Dion - Saturday, Mar 28, 2009 at 21:31
I have a 2m stiff bar with a 50mm ball coupling on each end. Dad's Slolux has a 50mm ball on the front of it, primarily for pushing the boat and caravan about.
The stiff bar has been used to pull the Slolux, and the Slolux has also been used to push around our other vehicles if required as we do maintenence on them.
In the QLD channel country, McIvers would stiff bar together five SAR KW triple cattle crates to make it through some
creek crossings. As the lead prime mover would be slipping as it exited the
creek until the drive got onto dry ground, the four behind were still pushing. By the time the 5th SAR was exiting the
creek, the other prime movers were
well and truly on dry gound and able to pull the last one out with ease.
It must have been an amazing spectacle what they did in the 70's, five GM powered two strokes double shuffling through the gears together with 30 decks of cattle!!
Dion.
356762
Follow Up By: kcandco - Sunday, Mar 29, 2009 at 20:14
Hi Dion
I was thinking 50 mm trailer coupling + approx 2 m bar as you have but not sure about end attached to vehicle being towed. Any suggestons? As each vehicle may have different
places to attach, ie bull bar, ??
regards Kc
624985
Reply By: Member - Axle - Saturday, Mar 28, 2009 at 22:45
Not sure whats legal?, what i do know is if towing with a rope, and the steerer in the towed vehicle is not up to scratch on knowing how to keep tension on the rope all the time , then your in for one hell of a ride!, bit like sitting on a bucking bull!!....LOL.
Cheers Axle.
356776
Reply By: DCTriton - Sunday, Mar 29, 2009 at 01:49
It was a long time ago but when I was in the army, "A" framing was the preferred tow method, legally(at the time) the towed vehicle was NOT allowed to be occupied - vehicles towed with a rope must (for obvious reasons) be occupied...
356786
