RB30 EFI Conversion
Submitted: Monday, Mar 30, 2009 at 18:26
Kev C
Hi All
After a year of a poor running RB30 in my Carbi GQ Patrol I have decided to explore the option of converting it to EFI.
I know that some
forum members have done this, but the details in the archive are sketchy. Has anyone documented the process?
I am planning on getting the EFI components, ECU & Oxygen sensor from a VL Commodore and installing a new EFI
fuel pump into the
tank. I still have some questions:
1)How do I get an ECU start signal?
2)Do I need a return
fuel line to the
tank? If so does it fit to the EFI
fuel pump?
3)Is there anything else I am missing?
I know that a lot
forum members have had good results from Russell in
Melbourne rejetting their Carbies. I have tried them but they will not work on the Carbi without the car. Unfortunatley I am about as far from
Melbourne as you can get & still be in Australia.
Kev C
Reply By: Member - DOZER- Monday, Mar 30, 2009 at 23:43
Mate, firstly, buy a gq 4.2 efi
tank, or if the vl pump will fit inside your
tank, then thats fine, do not mount it externally, you will have no end of bother. next, buy a complete running VL, and swap motor parts as required. use the complete loom/computer/fuse block etc, and wire in earth accessories and start from your key....fairly straight forward if you keep both systems intact.
MMMMturbo vl's are pretty cheap these days :)
Andrew
357168
Reply By: ExplorOz Team - Kerry W (QLD) - Monday, Mar 30, 2009 at 23:45
Do a
forum search on "RB30".
Basically this engine needs extractors, plus a free flow or straight through exhaust. Ensure the obstructions are out of the carby and inlet manifod. Make sure not any any blow by in the valves.
Make sure carby and dizzy are working properly.
Then run on premium
fuel and shift gears about 1000-1500 rpm higher than most other engines.
Remember this is the engine out of the early Skylines it is a racing engine detuned in standard form. It is designed to rev out to 4-5000rpm when you need some grunt.
Use 5th grear as overdrive only, keep it in 4th most of the time, it will happily do 100 KPH in 3rd gear and possibly use less
fuel than when struggling to do 90KPH in 5th gear.
Rev it!! It will still do 400-500,000 klm without a major overhaul.
Once you do all of the above -There is not much additional power to be gained by
fuel injection unless you take the step of throwing on a Turbo or supercharger.
If you do turbo it, they will handle around 400 BHP without major internal upgrades (crankshafts and pistons)
Check out the Skyline forums also for some good tips on how to get the most out of this engine.
http://www.skylinesaustralia.com/forums/forums.htm
Great engine just very misunderstood.l
Hope this helps.
| Kerry W (Qld)
-Helen KellerLifetime Member My Profile My Blog Send Message |
357169
Reply By: Robin Miller - Tuesday, Mar 31, 2009 at 07:57
Hi Kev
Start signal - did
mine via 1 k resistor from starter motor back to ecu.
Fuel pump needs return line - can't remember at moment how i did
mine
but for
fuel pump I fitted to driver chassis rail near the
tank using the vl bracket which I re-bent (I taped 2 6mm holes in chassis rail to hold and just ran
fuel line back into
tank).
I used ECU from an auto which shuts down
fuel in a different way from manual and so had to supply extra signals.
Manual ECU would have been better.
Was tricky due to loom and getting it thru firewall but i fitted ECU at passenger kick panel.
You can only get the 100kw engine up to 110kw with this conversion as cam profile is different , but I used extractors as
well to get to 115kw.
Was a useful mod as it gave increased torque for 4wding , but before this I had carby version up to 145kw and no torque.
I didn't have option 10 years ago but If I was to uprate an RB30
today I would take my time and fit an ecotec engine instead.
357196
