Posting Photos
Submitted: Tuesday, Mar 31, 2009 at 17:48
Member - Oldbaz. NSW.
Can someone explain to me ,in very simple language, how to post photos ? The pics are in a "My Pictures" folder with IMG numbers.
How do I get them from there to the "Insert Image" box ?
Just bursting to impress with my fishing prowess, but too dumb
to make it happen......oldbaz.
Reply By: Member - John and Val W (ACT) - Tuesday, Mar 31, 2009 at 17:53
Click on the "post reply" box
Click on "insert image" box in the bottom line of buttons. You should then be able to navigate through your computer to the image that you want to insert.
You may first need to resize your photos so that they are not too large, but maybe this site is smart enough to do that for you?
HTH
Val
| J and V
- Albert Einstein
357299
Follow Up By: Member - Oldbaz. NSW. - Tuesday, Mar 31, 2009 at 18:07
Hi Val, I can find the "insert image ' box & can "browse through to find the photo. What do I put in the "new file" & "description"
boxes to make it work ? If I put 'My Pictures" & the IMG
number it just seems to say "loading" forever...oldbaz
625387
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 18:32
Ob
You have to 'Browse' your computer to find where your photo is stored. Then click on that photo and it will appear in 'New File'
You do not need to fill in 'description' unless you want to. That just denotes a tag at the bottom of the photo.
Your problem may be in resizing your photos. You have to get them down to 800pixels wide before you can insert them. Do you have software for this?
625398
Follow Up By: Member - John and Val W (ACT) - Tuesday, Mar 31, 2009 at 18:42
Probably you need to reduce the size of your photo files. Use your photo editor to "resize" your photos. If you make the long side of the photo a maximum of about 800 pixels you should be OK. Save the resized image using the "save as" button and give it a new name so that you dont loose your original big photo.
Val
| J and V
- Albert Einstein
625399
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 18:51
And another thing....just to confuse you even more.....it is best to make a copy of the photo which you are going to resize. Put this photo in the same file or another one and then resize the latter.
I use Arcsoft Photostudio 2000, MS software. It is simple to use especially for someone with an older brain like me...LOL
625402
Reply By: Member - Rob S (NSW) - Tuesday, Mar 31, 2009 at 18:44
Hi Oldbaz
Depends on how many mega pixels dosn't take long to load a 5mega pixel photo but a 10mega pixel takes for ever.
If the pictures arn't resized it will do it for you. but will take a while for them to load,just select one at a time.
If you select more than one picture it will time out .
That works for me.
I don't know how to resize the photos
But may be some one will give us clue.
Rob.
357307
Reply By: Member - Fred G NSW - Tuesday, Mar 31, 2009 at 19:17
I've only got a 19" monitor, so I reckon oldbaz will have to resize them fish to fit onto my screen...LOL LOL ...
Can't wait to see them oldbaz...c'mon, you can do it :-)
Fred
357311
Follow Up By: Member - Fred G NSW - Tuesday, Mar 31, 2009 at 19:39
I learnt from instructions Doug TNT put up a couple of years back. Very easy to follow, maybe Doug is lurking tonight, and can set you right also OB.
625416
Follow Up By: Member - Doug T (NT) - Tuesday, Mar 31, 2009 at 22:38
Fred
I'm always lurking...lol but Hairs & Fysh has done the job.
625471
Reply By: Member No 1- Tuesday, Mar 31, 2009 at 19:26
get some PVA glue and paste em on....:))))
(in other words, I dont really want to see your fishing pics as i will most likely go green with envy)
357314
Follow Up By: Member No 1- Tuesday, Mar 31, 2009 at 19:30
Image Could Not Be Found
625413
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 19:35
Gee, you've aged since I saw you last......Looks like all that white hair on top has fallen down to yer chin.......hahahaha
625414
Follow Up By: Member - Doug T (NT) - Tuesday, Mar 31, 2009 at 22:53
625477
Follow Up By: Member No 1- Wednesday, Apr 01, 2009 at 04:21
hahaha
very funny you two
its not me holding that mulloway Willem...i dont.err cant catch em that big
625491
Reply By: Member - Mick O (VIC) - Tuesday, Mar 31, 2009 at 20:26
Baz, if you typing a reply or a blog, go to the "Insert image" button at the bottom of the dialoge box.
2. That opens a dialogue box that gives you two options to upload a photo a) Web hosted photo or b) Upload photo.
3. select the "Upload Photo" option by selecting 'Browse' under that heading.
4. That should take you to the next dialogue box which is basically the same as a "Windows explorer" page. You just click on the "look in" dropdown menu at the top of the page and select the appropriate folder that you keep your pictures in ie: 'My Pictures".
5. This will take you to the folder with your photos in it. If it is in file view and you want to see the photos click on the tab to the very right of the folder address (It's called "file view" when you hover the curser over it ). Left click and select Thumbnail from the drop down list. The photos will now appear as thumbs for you.
6. To select the appropriate photo, double click it and it will take you right back to the original Photo select box. This time the photo address will be in the top line. Click on the line below and type the photo description you want and then click the "LOAD" button.
7. The photo will now appear on your blog or reply.
You can see the results by clicking "Preview" from the buttons below as
well. This allows you to have a practice and then just cancel the answer or blog rather than submit.
If the photo is 2 meg or so it will take a little while to load. The smaller the file size, the quicker it will upload.
Hope that was clear enough.
Give it a go.
Cheers Mick
(P.S. It's also in post 66664)
357317
Reply By: Hairs & Fysh (NSW) - Tuesday, Mar 31, 2009 at 20:29
Hi Oldbaz,
This might you and others that may have trouble with loading pictures.
1) Click on reply, whether it be to a post or a reply.
Type in your reply or comment. were you cursor is, is were the picture will start from.
2) Browse to the location on your computer eg; my pictures
Find the picture you want to add to your post.
3) Open the file and then load it. You can give it name/title.
4) Preview you handy work, if need be resize the picture using paint or another program so it's not to big, if your happy with it click the Submit button.
Hope this helps.
357318
Follow Up By: Member - Mark G Gulmarrad - Tuesday, Mar 31, 2009 at 22:43
Jon
gees thats a gooood lookin' navara!!!
625474
Follow Up By: Hairs & Fysh (NSW) - Wednesday, Apr 01, 2009 at 05:19
Oldbaz.
As it was a rush job, I didn't have time to resize the picture or crop all the crap out of it.
HA HA HA LOL
625493
Follow Up By: Member - Oldbaz. NSW. - Wednesday, Apr 01, 2009 at 10:19
G'day Jon, I have followed your excellent cues & all works fine..
load takes a little while..pic is 1.49mb..but all that appears in reply
is a series of numbers/ pic 1...no picture. Where am I going wrong ??
...oldbaz.
625527
Follow Up By: Hairs & Fysh (NSW) - Wednesday, Apr 01, 2009 at 10:55
Hi Oldbaz,
When you first insert the Photo into the reply/Post, it does show up as a code that looks like this
[if]/170202.135/Forum/Pic_41[/fi]
If you preview the reply/post it will then show up as a photo.
You may have to scroll down the page a little to see your preview.
Practice an insert photo in a reply to this post. And see how you go. :)
If you happy with it then hit the Submit Button.
Hope this helps.
625532
Follow Up By: Hairs & Fysh (NSW) - Wednesday, Apr 01, 2009 at 11:06
Another trick is to save the picture as a JPEG, which is a lot small in pixel size that other formats. There are converts about that can do this.
A program that I use to resize and convert picture with is Easy Thumbnails, free addition. You can Get it
HERE Someone on these forums mentioned it one day. It a handy program.
625535
Follow Up By: Member - Oldbaz. NSW. - Wednesday, Apr 01, 2009 at 14:26
Success at last, thanks Jon.....oldbaz
625561
Follow Up By: Hairs & Fysh (NSW) - Wednesday, Apr 01, 2009 at 15:30
Oldbaz,
I've see your picture below, Good Stuff.
Glad I could help.
625570
Reply By: Robin Miller - Wednesday, Apr 01, 2009 at 13:58
Thought I'd try out the instructions with shot of well known
suspension bridge at Murrindindi.Image Could Not Be Found
357428
Reply By: Member - Oldbaz. NSW. - Wednesday, Apr 01, 2009 at 14:25
Following Jons advice...here goes....Image Could Not Be Found
357433
Follow Up By: Sir Kev & Darkie - Wednesday, Apr 01, 2009 at 14:53
So you only caught a Fingerling ;)
Cheers Kev
| Russell Coight:
625562
