Sat Phone again and again
Submitted: Wednesday, Apr 01, 2009 at 06:22
ThreadID: 67392 Views:2725 Replies:4 FollowUps:5
Has been covered extensively but still confused.
If I put my NextG sim card with international roaming enabled and 1900 allowed and I am on a plan, then my sat phone will work at say the Lone Gum in the Simpson Desert, where I am sure there is no Next G coverage? I am currently using TR Telecom as my Iridium provider, but have to use prefixes before dialling.
Krakka
Reply By: George_M - Wednesday, Apr 01, 2009 at 07:04
That's correct, Krakka.
Although the Iridium handset and operating frequency are different to the GSM/NextG handsets and frequencies, they all use the same sim-card technology to identify you and your account. This applies to Telstra services only - you cannot use a non-Telstra sim card (other than an Iridium sim) in an Iridium phone.
Not sure what you mean about the "prefixes" before dialling. I don't use the international codes on my device.
George
Come any closer and I'll rip your throat out!
AnswerID: 357358
Follow Up By: Krakka - Wednesday, Apr 01, 2009 at 09:13
That could be because I am using TR Telecom as my provider. Have to use different prefixes depending if I am dialling a land line, mobile No. or a sat phone. For someone to ring me, they have to do the same.
A pain in the ......
Krakka
FollowupID: 625512
Reply By: Ozhumvee - Wednesday, Apr 01, 2009 at 08:07
As you are using TR Telecom as your Iridium provider what works with an Iridium phone which has Telstra as the provider will/may not work.
If the same parameters apply then only a SIM provided by TR Telecom will work in your Iridium satphone.
The Telstra Next G and GSM SIM's work when enabled for international roaming because the PROVIDER is the same.
In a nutshell I don't think a Telstra Next G SIM or anyone elses SIM will work in your Iridium phone except for a SIM provided by TR Telecom.
AnswerID: 357370
Follow Up By: Member - Mike DID - Wednesday, Apr 01, 2009 at 08:42
The phone only works out who your provider is based on the SIMcard you have in it at the time.
It doesn't matter who you bought the Satphone from.
FollowupID: 625507
Follow Up By: Krakka - Wednesday, Apr 01, 2009 at 09:14
Yeah, I bought the Sat phone off Telstra about 8 years ago.
Krakka
FollowupID: 625513
Reply By: Member - Mike DID - Wednesday, Apr 01, 2009 at 08:39
An Iridium Satphone can ONLY work to Iridium satellites - it will not work to any national networks, even for emergency calls.
How it works depends on which SIMcard you put in it. Motorola 9500 can only receive SMS - 9505, 9505a, 9555 can receive and send SMS.
If you put a Telstra Mobilesat Simcard or a TR Telecom Iridium SIMcard in it, it works as a Satphone using International numbering no matter where in the world you are. These usually cost a minimum of $30 a month and you get assigned an International Number you can use anywhere in the world.
If you put a Telstra SIMcard (GSM or NextG) that is enabled for International Roaming, is not Prepaid and is not barred from 1900 calls, it will be recognised by the Iridium Network. You must be in Australia.
Outgoing calls to Australian numbers and INCOMING calls are charged at abt $3 a minute.
It will work like an Australian Mobile phone in terms of numbering - for incoming and outgoing voice calls you just use the normal national numbers (02 xxxx xxxx, 04xx xxx xxx).
You can send SMS to any phone in Australia, but you can ONLY receive SMS's from a Telstra Mobile - NOT from Optus, Vodaphone etc.
AnswerID: 357374
Follow Up By: Krakka - Wednesday, Apr 01, 2009 at 09:15
Thanks Mike
Krakka
FollowupID: 625515
Follow Up By: Robert HL (SEQ)(aka zuksctr) - Wednesday, Apr 01, 2009 at 14:24
G'day Mike,as you have probably read in another thread 67382 i am going through this process at the moment i have done every thing that is mentioned so far & nothing, zilch,is there something i am missing here,i don't know but is getting beyond me.
Still & all i thank everbody for there in put to my Q's i appreciate it.
Bob.
FollowupID: 625560
Reply By: Robert HL (SEQ)(aka zuksctr) - Saturday, Apr 04, 2009 at 08:00
Krakka did you get my return MM Friday evening? If not i willl let you know how i got on.
Bob.
AnswerID: 357967
