EO wheel cover size
Submitted: Wednesday, Apr 01, 2009 at 15:10
Member - Geoff the chef (NSW)M
Hi all,
I want to buy a wheel cover from the
shop for the back of the van.
The tyres on the van are 195 R 14C light truck tyres. When I use the selector in the
shop and put the afore mentioned size in it comes up with 190 85 14 and 001 size. Have I got the correct size?.
regards,
Geoff
Reply By: ExplorOz - David & Michelle - Wednesday, Apr 01, 2009 at 15:48
You can confirm the size of the calc system by measuring the tyre with a tape can comparing the diameter of the actual tyre and the conversion system. The calc system uses fairly basic formulas and I am sure these are correct so I would say it is right however a measure of the diamneter will ensure and the sizes are actually based on the diameter.
David
357451
Follow Up By: Member - Cram (Newcastle NSW) - Wednesday, Apr 01, 2009 at 16:26
I recently used thie calculator and
mine fits fine.
625579
Follow Up By: Member - Geoff the chef (NSW)M - Wednesday, Apr 01, 2009 at 17:12
Thanks David, it comes into 2150 range so i think an 003 might be it.
cheers Geoff
625586
Follow Up By: ExplorOz - David & Michelle - Wednesday, Apr 01, 2009 at 17:14
I hope 2150 is the circumference and not the diameter! Just measure across the front edge to egde and let me know - I may need to adjust the formula a little if it said 1 not 3 so please let me know.
David
625589
Follow Up By: Member - Geoff the chef (NSW)M - Wednesday, Apr 01, 2009 at 17:14
hi Cram,
do you have 195r14 c tyres on your van?
is 003 the correct size?
cheers Geoff
625590
Follow Up By: Member - Geoff the chef (NSW)M - Wednesday, Apr 01, 2009 at 17:43
hi David,
the circumference is 1800
sidewall to sidewall is 195
dia across centre is 660
I might have to wait till tomorrow to get exact measurements as it is absolutly bucketting down here.
cheers Geoff
625599
