Toyota 1HZ ideal tappet setting, turbo/non turbo?
Submitted: Thursday, Apr 02, 2009 at 13:26
toyotabits.com
G'day all, any experience with different tappet settings for 1HZ turbo? different to non-turbo? thanks, aussiedingo
Reply By: BarryBA - Thursday, Apr 02, 2009 at 14:47
You can find a complete 1HZ engine manual here
http://www.scribd.com/doc/7110020/1hd-1hz-1pzt-Engine - 348 pages of it . You might find what you are looking for there.
Barry
357678
Follow Up By: toyotabits.com - Thursday, Apr 02, 2009 at 16:27
Thanks Barry, I know the factory settings but some users prefer different settings for their turbo, thanks again, aussiedingo
625797
Reply By: Member - Phil G (SA) - Thursday, Apr 02, 2009 at 16:10
The valve clearance is not readily adjustable. To change the settings you'd have to change the 12 shims. Never heard of anyone going to that much trouble.
357683
Follow Up By: toyotabits.com - Thursday, Apr 02, 2009 at 16:25
G'day Phil, I am in the process of doing new pistons, rings & bearings, as
well as the head right now in my shed, I have heard a lot of different valve settings - want to hear more from experienced users, thanks for your reply, aussiedingo
625796
Follow Up By: Member - Phil G (SA) - Thursday, Apr 02, 2009 at 16:48
I wasn't sure whether you were referring to the factory turbo 1HD-T or a 1Hz with aftermarket turbo. But in any case, they have the same clearances:
Inlet 0.15-0.25mm
Exhaust 0.35-0.45mm
I have 3 manuals and a sticker under the bonnet of my daughter's 1Hz which all give the same specs.
The 1HD=FT 24 valve factory TD is totally different with adjustable tappets and slightly different clearances.
There a link to 1Hz clearances and an Excel spreadsheet
HERE.
625800
Follow Up By: toyotabits.com - Thursday, Apr 02, 2009 at 17:29
Thanks again Phil,
mine is a 1HZ with after market turbo, thanks again for the info
625803
Reply By: hotfishez - Thursday, Apr 02, 2009 at 16:39
If it is a 1HZ with after market TURBO set them to the open side of the specs.
STD Intake 1.5 - 2.5 set between 2.0 and 2.5 for turbo
STD Exhaust. 3.5 - 4.5 set between 4.0 and 4.5 for turbo
Factory 1HDT is the same specs I believe but check first
DO NOT GO OUT SIDE THE SPECS
357690
Follow Up By: toyotabits.com - Thursday, Apr 02, 2009 at 17:31
Thanks hotty, this is more what I'm looking for, aussiedingo
625804
Follow Up By: Member - Nick (TAS) - Friday, Apr 03, 2009 at 08:02
It usually better to set them on the higher side anyway so it takes longer for them to go out of spec again.
625892
