FJ73 - Taking off Door Trims HELP!!
Submitted: Thursday, Apr 02, 2009 at 15:10
ThreadID: 67446 Views:2140 Replies:2 FollowUps:1
Hey guys,
well as you know i bought myself an FJ73, the back left hand barn door is having problems with its central locking (after market i assume!) so i was going to take off the trim and have a wee look what the problem seems to be. So i unscrew the centre screw in the door release handle and expect to just be able to pull it straight out and off.. This isnt the case, i even tried on the other doors, not the case either. Is there some trick in getting the handle off so i can remove the trim? If anyone knows it would be greatly appreciated as its turning a 5 minute job into an hour long job! LOL
Help please!
Reply By: ross - Thursday, Apr 02, 2009 at 17:53
If you mean the plastic bit that opens the door from the inside, it has to be slid about 10mm to the right after removing the screw.
Then you have to flip the plastic clip and separate the rod from the mechanism .
I havent done a barn door before ,but it looks the same as the front doors.
To undo the plastic clips that hold the door trim to the door ,there is a range of tools at parts store starting at $5 .
AnswerID: 357700
Follow Up By: Member - Graham H (QLD) - Thursday, Apr 02, 2009 at 18:37
A good wide flat screwdriver or a thick bladed knife will save you the $5
LOL
FollowupID: 625814
Reply By: beccsptyltd - Thursday, Apr 02, 2009 at 19:20
Thanks very much fellas, saved me snaping off the door handle, lol, i was getting rather frustrated! hehe
Im not sure why id need a tool to release the plastic clips? I usually just pull them off with my fingers carefully.
But yeah thanks heaps guys!
Case CLOSED! hehe
JB
AnswerID: 357710
