exstending camping trailer
Submitted: Saturday, Apr 04, 2009 at 21:24
Member - shane (SA)
Hi all, I have a 8x5 tandem trailer with elec. brakes and i am wanting to extend it 4 feet. Doing the job is no problem, I will add 2 feet to each end. the problem is i don't want to change the draw bar, so it is going to be 2 foot shorter. Do you think this would be a problem?
shane.
Reply By: toyocrusa - Saturday, Apr 04, 2009 at 21:53
Yes it will. Draw it out to scale and see what happens
358081
Follow Up By: Member - shane (SA) - Saturday, Apr 04, 2009 at 22:15
I have done better, i added a 2 foot box to the front to see what would happen. No problems turning or doing anything else.
shane.
626183
Reply By: kevanancy - Saturday, Apr 04, 2009 at 22:15
I am pretty sure there is a ratio regarding how much in front of the axle and how much after , by adding 2feet to each end you would throw the balance of the trailer out . Prob illegal .
358084
Follow Up By: Wayne's 60 - Sunday, Apr 05, 2009 at 00:07
Would it follow from that theory, that the trailer was illegal to start? Or is the length of drawbar prorata as
well?
Wayne.
626206
Reply By: Member - Tony B (Malanda FNQ) - Sunday, Apr 05, 2009 at 10:26
Following links may help. Cheers Tony
SA Trailer Regs - Towing OnlyBuilding Trailers Info
358155
Follow Up By: Member - shane (SA) - Sunday, Apr 05, 2009 at 18:55
thanks for replies, Tony B, the links did not give a size or formula for the draw bar unless i mist something. So cant see a problem.
shane.
626345
Follow Up By: Richard Kovac - Sunday, Apr 05, 2009 at 22:23
Shane, check out item 17
17.2 Rear Overhang
Dog Trailers
Rear overhang must not exceed the lesser of:
-3.7m; or
-60% of the wheelbase.
Other Trailers
-3.7m; or
-front loading space.
17.3 Width
A trailer must not exceed 2.5 metres in width.
17.4 Height
A trailer must not exceed 4.3 metres in height.
17.5 Ground Clearance
The ground clearance of a trailer measured from the horizontal road surface of any point on the underside of the trailer except the tyres wheel and wheel hubs must when loaded to the ATM be not less than:
· 100mm for any point in the width of the vehicle which is within one metre fore and aft of any axle; and
· the dimension in millimetres obtained by multiplying the distance between any two consecutive axles in metres by 33.33 for the midpoint between those two axles. \
NOTE: OBSERVANCE OF PERMISSIBLE VEHICLE DIMENSIONS IS CRITICAL TO ROAD SAFETY. A TRAILER NOT MEETING THESE DIMENSIONAL
LIMITS MAY NOT BE ALLOWED TO OPERATE UNLESS PRIOR APPROVAL HAS BEEN OBTAINED FROM THE REGISTERING
AUTHORITY.
Richard
626373
