welding on towbar
Submitted: Sunday, Apr 05, 2009 at 20:07
ThreadID: 67563 Views:8496 Replies:5 FollowUps:8
I have to do a small welding job on my towbar entailing about 2 cm of welding rod. Do I have to take any precautions to protect the computer etc. Vehicle is a 97 pajero.
regards Kc
Reply By: Member - Graham H (QLD) - Sunday, Apr 05, 2009 at 20:10
Completely isolate the batteries
perhaps disconnect the alternator
AnswerID: 358230
Reply By: Blaze (Berri) - Sunday, Apr 05, 2009 at 20:25
Do it the smart way, remove the bar. Probably easier to clean and weld off the vehicle anyway.
If not I agree disconnect all batteries and alternator...
AnswerID: 358232
Follow Up By: Member - Graham H (QLD) - Sunday, Apr 05, 2009 at 20:29
Technically I believe it is illegal to modify your towbar IN ANY WAY.
I wanted to weld a new plate underneath to bolt my van chains onto but was told NO YOU CANT its certified as it is and has to stay that way.
FollowupID: 626352
Follow Up By: P7OFFROAD Accredited Driver Training - Sunday, Apr 05, 2009 at 20:36
That is my understanding also Graham, at least in QLD.
Dave
FollowupID: 626354
Follow Up By: Member - Roachie (SA) - Sunday, Apr 05, 2009 at 21:41
Surely it wouldn't be illegal to weld some bits onto your towbar? I've been going to remove mine, drill a hole in one of the corners of the box hitch receiver section, weld on a nut @ 45°, so that I can insert a bolt to stop the hitch from moving around. It's not a mod that would have anything to do with disturbing the integrity of the towbar.
Other mods people might want to do is add extensions facing the rear to enable them to use a high lift jack or add brackets to the underside to enable bolting up larger mudflaps etc.
I cannot see how any of these mods could be illegal..... but then again, you DID say it was Queerland....... hahahahaha
FollowupID: 626368
Follow Up By: Milodrinka - Sunday, Apr 05, 2009 at 22:53
Im with Roachie on this, i cant see any problem with welding a few bits to your towbar....I'll check this out with Littleborgy , he should know...
FollowupID: 626381
Follow Up By: Blaze (Berri) - Sunday, Apr 05, 2009 at 23:13
GDay Roachie,
I spoke to a Tow Bar engineering fiirm, in S.A. you can do anything you like as long as it doesn't change any structural strength. So no probs.
Warranty is another story. Heard of a guy who welded a step plate on his and bar eventually broke a weld on mounting plate at opposite end, yota refused warranty.
FollowupID: 626389
Follow Up By: Blaze (Berri) - Sunday, Apr 05, 2009 at 23:17
Graham,
To weld on a chain plate would be a structural change, so illegal anywhere I believe, as that plate is expected to hold the van should it come off the hitch, to be honest IMHOmost of these connection points, with 2 tonne of camper/van at even 80k's wouldn't hold it.
FollowupID: 626390
Follow Up By: Member - Graham H (QLD) - Monday, Apr 06, 2009 at 09:11
Well as you say Queerland may be different but it was the towbar palce I bought it off who told me that.
It has a fiddly little plate underneath on a 45o angle and is hard to hook up to so i asked them to put a large flat plate like the toyota ones.
They refused saying that the bars are certified as they are and cannot legally be modified in ANY WAY.
Their words not mine and they presumably are the experts.
FollowupID: 626419
Reply By: Hairy (NT) - Sunday, Apr 05, 2009 at 20:37
Gday,
I wouldnt??
If it was on my own car ( 80 series), I would just put the earth as close as possible to where Im welding and just make sure it is a GOOD earth.
AnswerID: 358237
Reply By: Member - Scrubcat (VIC) - Sunday, Apr 05, 2009 at 20:53
G`day Kc,
I had some welding done on the c/van while hooked up to the wagon yesterday, the bloke had a lead with a special gissmo on it that protected everything on the wagon and c/van, he fitted the ends of the lead to the pos & neg of the battery, a green LED light showed to indicate it was OK to weld. Too easy...
Scrubby.
AnswerID: 358243
Follow Up By: Blaze (Berri) - Sunday, Apr 05, 2009 at 23:21
Totally agree Scrubby but if you dont have that fitted, and most home users don't, remove the lot.
Lets face it, its only about $3,000 damage that can be caused if it all goes pear shape. Probably 9 out of 10 are fine, but wouldnt want mine to be number 10.
FollowupID: 626393
Reply By: Member - Stuart P (WA) - Monday, Apr 06, 2009 at 00:00
always isolate/ disconnect battery/ies once they are disconected the alternator is safe . as for wlding the tow not a problem , you are not changing any strength of the bar
AnswerID: 358268
