nuvi 760
Submitted: Saturday, Apr 11, 2009 at 14:24
gezza100
Wondering if anyone can tell me if the nuvi 760 has a "breadcrumb trail" or track marking capability.
Reply By: blue one - Saturday, Apr 11, 2009 at 14:53
Gezza,
Yes it has. It will mark a trail where you have been. It will also guide you back the where you left your car if on foot.
Very happy with
mine, it is loaded with Garmin City Navigator and OZtopo V2.1. You just switch between maps depending if you are in town or the bush.
Garmin have also just released topo maps of Aus and I think it has auto routing capabilities!
Steve
359193
Reply By: catweazl - Saturday, Apr 11, 2009 at 14:58
Yes it does.. Go to Menu then
Tools then Settings then Map .. You should see Trip Log .. Tap that for show or hide. Comes up as a blue line telling you where you have been .... Hope that works for you and what you wanted to know
359194
Follow Up By: Steve - Saturday, Apr 11, 2009 at 18:18
just looked at that on
mine and it shows a tiny map of the last few 100 meters (yep - I know you can zoom out) but how do you tell it to take you back or even move the map back along the route you've travelled?
627213
Reply By: catweazl - Saturday, Apr 11, 2009 at 21:05
I think you have to have it on for it show history.. By that i mean if it is off then u turn it on it only shows since being turned on.. Then the only way to follow it as far as i know is by looking and moving the map along with your finger.. ie slide your finger across the screen.. I dont think you can set the breadcrumb trail as a route as such
359237
Follow Up By: Member - Brenton H (SA) - Sunday, Apr 12, 2009 at 09:59
I assume by on/off in this case you mean to display track on/off as power on/off doesn't get rid of the track. Had so many blue track lines on
mine it became confusing after a few days...also lets the wife know where you have been. To the best of my knowledge your right that you can't set the reverse track as a route...you can only just turn around and follow the blue line. The garmin instruction manual is dam useless on this aspect.
627259
Follow Up By: gezza100 - Tuesday, Apr 14, 2009 at 07:42
thanks for all the inof to everyone, and on that point you raised about all the blue lines, can you reset or delate them altogether?
627418
Follow Up By: madcow - Tuesday, Apr 14, 2009 at 08:12
Yep you can send them to your pc using mapsource or just delete them by
clearing the trip log. I am pretty impressed with this unit. Have a look at doug and dusty's site for lots of info for this model.
http://www.doug-and-dusty.id.au/gps.htm
627421
