Galmet -Duragal
Submitted: Saturday, Apr 11, 2009 at 20:35
ThreadID: 67771 Views:6081 Replies:6 FollowUps:5
Hi Guy's does anyone know where I can buy Duragal in a spray can in NSW.
Need some for touch up on the Caravan and might give it a go on the Boat trailer and see how long it lasts.
Can't seem to find the stuff in Bunnings they have white knight products, and no one else has heard of the stuff.
Cheers Justin.
Reply By: Member - Paul C (WA) - Saturday, Apr 11, 2009 at 21:11
Blackwoods stock it.
AnswerID: 359238
Follow Up By: Roughasguts - Saturday, Apr 11, 2009 at 21:21
Thanks Paul. Hmmm Blackwoods is that in Singleton N.S.W.
I would prefer something on the Central coast that be a bit closer.
Cheers.
FollowupID: 627223
Follow Up By: Member - Paul C (WA) - Saturday, Apr 11, 2009 at 21:27
There's one at Tuggerah
FollowupID: 627224
Follow Up By: Roughasguts - Saturday, Apr 11, 2009 at 21:30
Thanks Paul... 12 mins down the road easy.
Cheers.
FollowupID: 627227
Reply By: Bushwhacker - Saturday, Apr 11, 2009 at 21:29
Hi, There's a Blackwoods at Wickham, and I think the new one is open at Beresfield, in the industrial estate. Oops, just had a look at heir website, doesnt mention Beresfield, so Wickham near Newcastle city centre best I can advise. Cheers, Dave
AnswerID: 359243
Follow Up By: Roughasguts - Saturday, Apr 11, 2009 at 21:31
Thanks Dave, appreciate the help.
FollowupID: 627229
Reply By: RV Powerstream P/L - Sunday, Apr 12, 2009 at 08:55
I reckon a Metaland outlet would be a good bet also as they carry most colourbond touch ups so duragal could be half a chance.
Ian
AnswerID: 359280
Reply By: Ozhumvee - Sunday, Apr 12, 2009 at 09:20
If you warm the steel prior to application it does seem to bond better. I just leave the box trailer out in the sun on a warm day and it is warm enough.
The local Mitre 10 has both the tins and the spray can here in Hornsby.
AnswerID: 359285
Reply By: Flywest - Sunday, Apr 12, 2009 at 17:25
After trying the galmet / duragal etc several times on a boat trailer i was dissapointed with how quickly rust re - appeared thru it.
When i rebuilt the trailer fully a year or so back - I decided to so the same treatement BUT afterwards i coated with the aluminium bitumenous tar stuff - and no sign of any recurring rust at all.
Only mistake I made was when i did the rims - I got the bitumenous aluminium paint onto the tyre valve stems and it melted the glue that holds the valve inside the rubber valve stem.
I run my tandem boat tyres at about 70psi and it belw all the valves out of the valve stems - so I ended up replacing all of them including the 2 spares.
Lesson learned - keep solvent based paints away from tyre valve stems.
AnswerID: 359319
Reply By: Member - Charlie M (SA) - Sunday, Apr 12, 2009 at 22:41
CRC Zincit is the same in various colors now.
Grey, bright zinc (silver) bleck, yellow.
As said Blackwoods, Repco, CBC Bearings, Motor Traders
Charlie
AnswerID: 359331
Follow Up By: Member - Charlie M (SA) - Sunday, Apr 12, 2009 at 22:45
bleck should be black
FollowupID: 627317
