Jimny fuel tank does not breath.
Submitted: Sunday, Apr 12, 2009 at 18:11
ThreadID: 67786 Views:4184 Replies:3 FollowUps:5
My Jimnys fuel tank cap is very hard to open when low on fuel. When you do loosen the fuel cap it sucks air in.Is this normal? Brian
Reply By: Member - William H (WA) - Sunday, Apr 12, 2009 at 18:45
what tank on what vehicle.......???????????
William.
AnswerID: 359323
Follow Up By: Brian P - Sunday, Apr 12, 2009 at 18:51
Suzuki Jimny petrol tank. Thanks Brian
FollowupID: 627298
Follow Up By: Member - William H (WA) - Sunday, Apr 12, 2009 at 19:14
Check all your vaccume lines to the tank, one could be blocked off.
Cheers for now...William H...Bunbury...WA.
FollowupID: 627304
Follow Up By: garrycol - Sunday, Apr 12, 2009 at 19:36
William - the original post did say what vehicle.
I do not know the specifics of your`vehicle but many Suzuki tanks vent to atmosphere via a charcoal canister - this prevents petrol fumes from the tank escaping. If the charcoal cannister is clogged which can happen over time the tank cannot vent so when fuel is sucked out by the pump there is a pressure decrease making the cap difficult to remove - the tank may also be being sucked in.
20 years ago I had a Sierra and the cannister was clogged with salt water after a deep crossing - my tank got sucked in and the cap would not come off - until I got it fixed I used a cheap plastic orange cap which let air in.
Garry
FollowupID: 627308
Follow Up By: Brian P - Sunday, Apr 12, 2009 at 20:05
Thanks to both of you will check it out tomorrow after work. Also can the canister be serviced by me?
FollowupID: 627311
Follow Up By: garrycol - Sunday, Apr 12, 2009 at 23:12
It is just a container full of charcoal - is a replacement item
FollowupID: 627320
Reply By: mechpete - Sunday, Apr 12, 2009 at 20:02
in my experience the fuel cap should have a valve to allow air to be sucked in from outside the but not pressurise itfrom inside . its called evaporative emission
mechpete
AnswerID: 359326
Reply By: Rangiephil - Monday, Apr 13, 2009 at 10:10
Modern tanks have breathing into the inlet manifold controlled by the ECU.
At low throttle and car moving they will open the EEC valve which then vents the carbon canister into the inlet, which is at high vacuum vs the atmosphere.
So it is normal after driving on a long trip for the tank to have vacuum, as the engine vacuum is transferred to the tank.
My Range Rover does the same.
Regard sPhilip A
AnswerID: 359354
