where can i buy a Latch like this
Submitted: Monday, Apr 13, 2009 at 13:45
ThreadID: 67795 Views:8966 Replies:9 FollowUps:8
i have added a second stub axel onto my Kaymar rear bar and i'm making a swing away jerry can holder up to go onto it. i now need to get a latch and locking bracket that is preferably the same as the one i will picture below. before you say try Kaymar i will be doing that this week, but i have been told they don't sell parts unless it's to replace already damaged ones, and then proof needs to be shown of damaged parts (phone call this week will confirm this or not though). so does anyone know where i can purchase one of these latches from, obviously from a looks point of view i want it to be the same as or very similar to the one pictured below.
cheers for any help
Reply By: Member - Malcolm (Townsville) - Monday, Apr 13, 2009 at 14:05
rumpig
Any body fabricator should have what you are looking for.
Malcolm
living the 'good life'
AnswerID: 359374
Reply By: garrycol - Monday, Apr 13, 2009 at 14:17
Any good trailer builder will sell them.
Garry
AnswerID: 359375
Follow Up By: awill4x4 - Monday, Apr 13, 2009 at 16:08
No they won't, those latches are Kaymar's own there is no other supplier that sells those latches.
This question comes up in all the 4x4 forums and it always comes down to the same answer, make your own or come up with some other solution because Kaymar will not supply them separately.
Regards Andrew.
FollowupID: 627380
Follow Up By: garrycol - Monday, Apr 13, 2009 at 21:10
Sorry - but my local trailer builder sells these type of latches.
FollowupID: 627401
Reply By: Member - Peter R (QLD) - Monday, Apr 13, 2009 at 16:51
Try a wrecker, they may have one.
Pedro
AnswerID: 359388
Reply By: Member - William H (WA) - Monday, Apr 13, 2009 at 18:06
Good afternoon rum pig.
Are these the ones you want.
Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
These parts are of the spare tyre holder from an early Toyota, BJ40's, Hj47 1982/84, and you should be able to get them from a wrecker, near you.
Cheers for now...William H...Bunbury...WA.
AnswerID: 359397
Follow Up By: rumpig - Monday, Apr 13, 2009 at 21:27
thanks William
a mate did suggest to me yesterday that i look at some of the old Toyota type ones. i may have to revisit the local wreckers and see what i can find should Kaymar not want to sell me an original one, though some of the catches sold at the trailer shops seem to be similar aswell looking at the link posted up.
FollowupID: 627404
Reply By: Louie the fly (SA) - Monday, Apr 13, 2009 at 19:04
rumpig, I built a swing away jerry can holder for my Kaymar rear bar (on a 92 4Runner). After deliberating long and hard (with beer) over how and where to latch it I decided to do it the easy peasy way. See my pics below.
You just have to make sure the new arm lines up with the Kaymar one. This you would do anyway otherwise it would look odd me thinks. Then just weld a plate on top and behind. I used 75 x 50 x3 RHS and the plates are 50x8 flat bar. I welded a piece of 16mm round bar to the bottom of the arm of the jerry holder so it just pushes up against the rear bar when the whole shebang is closed. No rattles or anything, and strong as an ox. Only thing is I didn't put a stop on it as I was in a hurray to go away. A few days into the trip and I ended up with a ding in the right rear 1/4 panel from it swinging out to far. How'd you be!
Louie
AnswerID: 359403
Follow Up By: rumpig - Monday, Apr 13, 2009 at 21:20
thanks for the pics and tip, i'm open to any suggestions at the moment, though i do want it to look as much as the original as possible. at the end of the day, if i can't get what i'm after, then i'll have to rethink how i build it.
FollowupID: 627403
Reply By: Member - Ed. C. (QLD) - Monday, Apr 13, 2009 at 19:11
If you can't find one as per your pic, then
Trailer Spare Parts Aust. have a couple which may suit your application..
catches
Confucius say.....
AnswerID: 359405
Reply By: rumpig - Monday, Apr 13, 2009 at 21:15
thanks for the replies so far everbody, i have emailed Kaymar in the off chance that they will sell me the Latch and catch, but honestly i don't like my chances.
i never thought to ask at trailer shops and manufacturers, so thanks for that heads up and the link. i had tried a couple of the local wreckers, but no luck, rare as rocking horse poo was what one wreckers said to me in relation to getting a Kaymar product, but i will continue to look. would be nice to stumble across a damaged rear bar or wheel carrier that had what i wanted, but i don't like my chances, won't stop me from looking though.
thanks again
Rumpig
AnswerID: 359421
Reply By: Michael ( Moss Vale NSW) - Monday, Apr 13, 2009 at 21:50
How about this one... $57 ea.. MichaelImage Could Not Be Found
AnswerID: 359426
Follow Up By: Michael ( Moss Vale NSW) - Monday, Apr 13, 2009 at 21:55
OOPS!!! www.ovesco.com.au Michael
FollowupID: 627405
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Apr 14, 2009 at 09:39
Also check out post #46907 on this site, apparently opposite lock have a heavy duty latch for about $70. Michael
FollowupID: 627426
Follow Up By: rumpig - Tuesday, Apr 14, 2009 at 17:06
thanks for that Michael, that thread was handy to read. i'll have a look at the Opp. Lock one and see what it looks like. that big yellow version looks ok if the other isn't what i want.
Rumpig
FollowupID: 627472
Reply By: rumpig - Tuesday, Apr 14, 2009 at 17:10
as much as i don't like the answer, Kaymar are atleast quick to reply to emails, but like expected they replied, "we don't sell the catch seperately". so only way to get same catch is to spend over $700 on a new complete holder, which i won't be doing.
thanks for your help again everybody.
AnswerID: 359530
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Apr 14, 2009 at 20:50
Let us know the outcome of your Quest!!! Michael
FollowupID: 627530
