fly wire repair kits - any suggestions?
Submitted: Sunday, Apr 19, 2009 at 20:31
kingswoodwagon
Hi all,
Does anyone know of a fly wire repair kit I can use on a Jayco CT?
I'm particularly after some brand names as I need to buy online.
Thanx in advance for any ideas
Reply By: Roughasguts - Sunday, Apr 19, 2009 at 20:49
Are you going to replace the whole screen, or just put a temporary patch on a hole in the existing screen?
360424
Follow Up By: kingswoodwagon - Sunday, Apr 19, 2009 at 21:13
Good question,
I have about 6 small tears all under 100mm long.
I'm hoping there is some sort of repair available for those.
Thanx
628217
Reply By: Member - Nick (TAS) - Sunday, Apr 19, 2009 at 21:12
We cut a hole in the flywire window in our camper to fit an air conditioner in while living in it in
Kununurra.Once we moved into our house, I purchased a piece of fly screen from the local upholstery guy and stiched it in.I over lapped it 20mm and sewed both edges.Came up great but took ages (needed a few breaks as you go cross eyed looking at them little holes for so long)
360431
Reply By: Roughasguts - Sunday, Apr 19, 2009 at 21:25
I used off cuts from replacing door screen on some small holes, and used some clear silastic to glue it in place.
Contact may have been better as it took a while to set.
But Really hard to find where I patched it now as it's in the kids bedrooms I hardly look out there windows anyway.
360435
Reply By: Member - Scrubcat (VIC) - Sunday, Apr 19, 2009 at 22:20
If you`r not worried about appearance just stick some tape over the hole on both sides. i.e. sticky side to sticky side. Plenty of suitable types of tape available these days.
Good luck.
Scrubby.
360449
Reply By: Member - Mark G Gulmarrad - Sunday, Apr 19, 2009 at 22:51
Kingswoodwagon
i know that BCF have a kit especially for you needs.......we have one in our camper for repairs.
360452
Reply By: PradOz - Sunday, Apr 19, 2009 at 23:59
depending on where the holes/splits are, you can fit a new screen patch over the hole by overlapping the new piece by 20mm or so and fusing the two (new and old screens) together with heat from a soldering iron or similar on new side and using a piece of metal/steel on the other side behind old screen (need extra set of hands to help hold it). just try it out first on some scrap screen material to get it right (how long to leave heat on, amount of force etc)
360459
Reply By: trainslux - Tuesday, Apr 21, 2009 at 10:00
All we have done on our tents, and canopy is just get some thread of the same colour, and slowly stitch up the 2 sides back together, takes a bit of time, but works a treat, no mossies in the tent. Just loop thru and follow the squares all the way down.
Trains
360670
