Aftermarket turbo
Submitted: Monday, Apr 20, 2009 at 14:53
ThreadID: 68041 Views:2608 Replies:6 FollowUps:0
Hi all,
A question for the owners of aftermarket turbo'ed 100 1HZ, 100 series.
What boost do you run?
Reply By: ob - Monday, Apr 20, 2009 at 15:22
Just in the process of putting a turbo on a 1HZ. The turbo supplier (Turbotech in Perth) said stay below 8psi and you should get about 25-30% increase in power without damaging anything.
Cheers ob
AnswerID: 360538
Reply By: Member - Nick (TAS) - Monday, Apr 20, 2009 at 15:52
Turbo'ed mine about 6 months ago.I set it up for 11psi max boost.
Id be more worried about your EGT's than boost as EGT's will climb as boost increases anyway.You dont want your EGT's to climb above 550deg C post turbo.
Driving ours at 95kph we get around 300 deg C EGT's and boost about 8psi.
AnswerID: 360540
Reply By: Member - Chris & Debbie (QLD) - Monday, Apr 20, 2009 at 16:33
Gezza
I only fitted a Denco kit to my 1hz a couple of months ago and the boost was factory set to 8psi, but after fitting an egt gauge I found that the egt did not get much about 400degC post turbo and did not have the power increase I was expecting.
Because of this a dyno was done last week, the tuner increased boost to 9psi and increased the fuel as it was running way to lean. These adjustments increased allowed the egt to peak just over 500degC post turbo and the power increase was more what I was expecting from adding the turbo. The dyno graph showed 97hp before the dyno which is about standard and increase to 120hp after.
Chris
AnswerID: 360548
Reply By: Scott C (Coolum - QLD) - Monday, Apr 20, 2009 at 20:14
Hi gezza
I run mine at 12psi, had in on for 5 years and done about 120K.
Cheers Scott
AnswerID: 360592
Reply By: Dremus - Tuesday, Apr 21, 2009 at 13:39
Had an denco on my 1HZ 80 series with 2 1/2 inch exhaust, running 7 psi and it was marginally better than unturboed. Never had any issues either.
Now have a denco on my HZJ 105 with 1 HZ and 3 inch exhaust, set at 10 psi but it maxed at 12 psi on the dyno. It has a heap more power and using a bit more fuel but well worth it.
AnswerID: 360688
Reply By: gezza100 - Thursday, Apr 23, 2009 at 09:05
Thanks to everyone for their input, have got an egt, new big end bearings, 3inch exhaust and heavy duty clutch.
AnswerID: 361036
