Fitting Brake Controller to a P38 Range Pover
Submitted: Wednesday, Apr 22, 2009 at 10:36
ThreadID: 68098 Views:3102 Replies:2 FollowUps:0
I have purchased a brake controller (Prodigy) for my P38 RR and was about to install - an easy job - when I noted that the P38 uses all 7 electrical connections. Land Rover in their wisdom also provide sep power for left and right running lights. Obviously I shall need to modify the wiring slightly to accommodate - but which pin is usually(?) used for the purpose of electric trailer brakes on, say, a Jayco camper trailer?
Reply By: al - Wednesday, Apr 22, 2009 at 11:34
hi T
just fitted two prodigy brake controllers one to a gu patrol, one in a 80 series cruzer we used no. 5 pin on both and tried on a caravan and a trak shak camper trailer both worked fine hope this helps.
regards
all
AnswerID: 360862
Reply By: The Initials - Wednesday, Apr 22, 2009 at 11:46
Many thanks - it is as I thought it would be (pin 5). The Rangie standard wiring loom uses pin 5 for the 'Left Rear Side Lamps'. I shall just have a quick rewire job and all should be good.
AnswerID: 360865
