diff breathers
Submitted: Sunday, Apr 26, 2009 at 14:20
ThreadID: 68234 Views:3664 Replies:4 FollowUps:1
G day all. I was just wondering if it was a necesssity to fit Diff Breathers to the X Trail for the up comming trip to Cape York.
If so where would the best way to route them. Do I need one for the front drive??
Reply By: Member - Fred B (NT) - Sunday, Apr 26, 2009 at 14:44
I don't know anything about the X trail, but... if going through water crossings diff breathers are essential. Diffs change temprature depending on circumstances, hence the need for breathers. You don't want the diff sucking moisture or sand at the wrong time. They are not supposed to let water ecetera back in, but it happens. Anytime you get air moving in or out it's going to happen.
Either fit breathers or check your oil for water as soon as possible afterwards.
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 361654
Reply By: CJ - Sunday, Apr 26, 2009 at 15:05
YES is the simple answer
AnswerID: 361660
Reply By: RobAck - Sunday, Apr 26, 2009 at 18:34
For a Cape York trip diff breathers are essential and more so than a snorkel. People do not understand that most diff breathers, particularly those fitted to SUV but also a lot of 4WD sit on the top of the axle. So even crossing water at hub height will casue it to flow over the axle and allow the breather to suck it in with subsequent damage to diff and axles. There are plenty of reasonably priced kits just make sure the breathers are placed in the engine bay on the firewall as high as practicable
RobA
AnswerID: 361702
Follow Up By: Member - Phil G (SA) - Sunday, Apr 26, 2009 at 21:29
Gday Rob,
Xtrails, like most smaller SUVs are independant suspension front and rear, so axles are sealed. The diffs already have extended breathers.
FollowupID: 629482
Reply By: Member - Phil G (SA) - Sunday, Apr 26, 2009 at 21:25
The T30 Xtrail already has diff breather tubes - the front has a hose going up near the airbox and the rear has a hose going up into a crossmember.
Link here
I'd be more worried about the air intake. You'll need a blind for any reasonably deep crossing.
AnswerID: 361740
