Starter Motor
Submitted: Sunday, Apr 26, 2009 at 19:35
Member - Rod V (WA)
Would anybody know what the current draw is on a Nissan patrol 4.2 diesel starter motor, I am reading 9.5 volts when the starter
is under load, the battery if fully charged
Reply By: Chev-Patrol 6.5 V8 D - Sunday, Apr 26, 2009 at 19:45
That sounds about right.....If it's spinning-up okay and starts okay (you can tell from the sound of it as it starts whether the battery is alright or night), then you're okay.
361718
Follow Up By: Member - Rod V (WA) - Sunday, Apr 26, 2009 at 21:08
It takes about to 9 seconds for the engine to fire, some say it the starter isn't spinning fast enough for the engine to fire
629476
Reply By: Ozboc - Sunday, Apr 26, 2009 at 20:29
going from memory - ( if your talking amperage draw) i think i seen
mine hit about 80 - 100 amps for a brief second
thats was about a year ago - would have to bring my clamp meter home from work again if you really need to get a more accurate measurement
Boc
361730
Follow Up By: Nomadic Navara - Sunday, Apr 26, 2009 at 21:11
Sedans draw 350 A or more, A diesel would likely to be in the region of 600 -1000 A
629477
Follow Up By: Member - DOZER- Monday, Apr 27, 2009 at 10:44
years ago we put a gauge on a diesel hilux and it spiked at 450 amps before running ay 250 till it started. You have a few options, first check all terminals to block and starter, check wires are in good condition, get battery checked with load meter, and if all else fails, pull starter and renew contacts....but yes, 9 volts under load would be about right.
Andrew
629552
Reply By: furph - Monday, Apr 27, 2009 at 08:14
The starter motor is possibly rated at 2.5kw.
If this is the case, current draw would be 2500/12 = 208a.
But if the battery voltage drops down to (say) 10v under load the current draw would increase to 250a.
furph
361777
