Auto Electrician mobile Melbourne
Submitted: Monday, Apr 27, 2009 at 13:51
ThreadID: 68273 Views:3887 Replies:2 FollowUps:5
Hi does anyone know and can recommend a mobile auto electrician close to Melb CBD. I need some work done on both car and 2007 jayco campertrailer - namely replacing existing 7 pin plug with Anderson, checking if there is a problem with van fridge which doesn't appear to run on 12v, upgrading wiring to a heavier gauge on both car and van if necessary. Van has onboard 100amp deep cycle battery which is just running the lights but also thinking of installing an inverter.
Meerkat
Reply By: Shaz & Col - Monday, Apr 27, 2009 at 15:14
Caravan Electrics provide a come to you service depending on your location and they specialise in low voltage.
call
0417 595 505.
AnswerID: 361863
Follow Up By: meerkat - Wednesday, Apr 29, 2009 at 11:03
Thankyou, will follow them up - couldn't find them in the yellow pages or business directly though.
FollowupID: 629982
Follow Up By: Shaz & Col - Wednesday, Apr 29, 2009 at 17:26
Hi Meerkat, they are a small mobile company , they advertise in a couple of the caravan mags and they come to you.
FollowupID: 630046
Reply By: Member - Lance S (VIC) - Tuesday, Apr 28, 2009 at 16:48
Meerkat, i use Duncans auto elec. in York st . South Melbourne
9690 2039 Ask for Chris, tell him Lance sent you, he looks after all our work trucks and my 4wd. He did all my wiring on my 4wd and camper.
cheers,
Lance
Home Away from Home
AnswerID: 362069
Follow Up By: Inkbandit79 - Tuesday, Apr 28, 2009 at 21:08
Can second duncan auto elec, Chris is a top bloke he used to do all my work when i lived in Melbourne, say g'day to him if you see him from Aaron in W.A.
FollowupID: 629886
Follow Up By: meerkat - Wednesday, Apr 29, 2009 at 11:05
Thanks heaps - hard to find auto elec that know enough about vans. Lance, did you use 6 or 8mm wiring?
FollowupID: 629983
Follow Up By: Member - Lance S (VIC) - Wednesday, Apr 29, 2009 at 15:18
8mm with 50amp anderson plugs
Home Away from Home
FollowupID: 630018
