Quick LR Disco question...........
Submitted: Wednesday, Apr 29, 2009 at 11:12
Martyn (WA)
Forumites,
Just a quick question, I had a LR Disco with slightly bigger than normal tyres on standard rims, I'm buggered if I can remember what size these tyres were. They did contact the rear arch ever so slightly on full articulation yes I'm aware of this I'm going to get the rear arches trimmed to suit I just need to know the size.
Yeap I've got another Disco now with standard tyres I just want to go a little bit bigger with out doing major mods.
Thanks in anticipation.
Reply By: Rangiephil - Wednesday, Apr 29, 2009 at 11:26
size is 245.75x16.
Regards Philip A
362227
Reply By: Ozrover - Wednesday, Apr 29, 2009 at 18:16
Gerday Martyn,
I've had both a Disco 1 & a Disco 2, the first one came with 31/10.5/15s (2nd hand) fitted & touched the guards slightly, I fitted 33/12.5/15s & had to trim the rear of both front & back guards to stop them from touching, I also gave it a 4"
suspension lift as
The Disco 2 came new with 235/70/16s & I fitted it with 245/75/16 MTRs, as
well as OME touring
suspension, approx' 40mm lift & had no problems with the tyres touching at all.
Hope this helps.
362300
Reply By: Member - ian R1 (NSW) - Wednesday, Apr 29, 2009 at 19:53
Martin,
I note from your profile that your Disco is a D3 TDV6 S.
The standard tyre is 235/70R17.
A 245/70R17 will fit without any rubbing. A 265/?R17 will rub on some model years, due to some differences in chassis rails - not sure of details.
I have 245/70R17 Cooper STTs on aftermarket
wheels for trips/offroad use.
362316
Follow Up By: Martyn (WA) - Wednesday, Apr 29, 2009 at 19:59
Hi Ian,
Very true, I do have an 05 Disco 3 but I also have a project 97 LR Disco 2.5 TD which I play with in my spare time which isn't a great deal right now. Impressive observation......... The size I was after was in the first response, thanks very much anyway.
630069
