Water in Lake Eyre.
Submitted: Tuesday, May 05, 2009 at 19:58
Tony
The wife wants to go to Lake Eyre in July to see the
water.
Where would the best place to view
the Lake? We would be heading up the
Birdsville Track.
Reply By: Member - Kiwi Kia - Tuesday, May 05, 2009 at 20:03
You really need to fly over
the lake. Closest point would be
William Creek.
363400
Follow Up By: Tony - Tuesday, May 05, 2009 at 20:07
Thanks mate, didn't want to go up to William Cr, then back trak to Maree.
631036
Follow Up By: Willem - Tuesday, May 05, 2009 at 21:30
Tony have a look at a map. There is no access from the
Birdsville Track to Lake Eyre.
631058
Follow Up By: Member - DOZER- Tuesday, May 05, 2009 at 21:44
Tony
Have a search in the archives, there are 3 or more
places you can catch a flight from, each have their drawbacks,
Birdsville is cut off from the simpson by road at the moment, but by July things might be different. Been thinking of going for a drive to Coongie lakes myself with my trusty canoe
Andrew
631064
Follow Up By: Tony - Wednesday, May 06, 2009 at 06:08
Thanks Willem & DOZER, it looks like there is good
camping at
Muloorina Station. A track then goes to
Level Post Bay, so if the level is up
water can be seen from there.
Going OS for two months and will get back 12th July so will have to check to see if there is enough
water to be seen from
Level Post Bay.
631090
Follow Up By: Willem - Wednesday, May 06, 2009 at 08:37
Yes, Muloorina has a nice
camping area right on the
overflow from the artesian
bore.
Camping cost is still a donation I believe.
The road to
Level Post Bay from Muloorina is normally not very exciting (corrugations) but if the
water has reached that spot you should get a good view.
631115
Follow Up By: Tony - Wednesday, May 06, 2009 at 08:48
Thanks Willem. Will have to wait and see what its like in July.
631117
Follow Up By: Member - Phil G (SA) - Wednesday, May 06, 2009 at 08:49
I would be surprised if
Level Post Bay.
The Lake needs to be a lot fuller than it is at present. But yes, its a
good campsite.
Some photos were posted a couple of weeks back from Halligan's Bay where the
water was within a few hundred metres of shore.
631118
Reply By: MEMBER - Darian (SA) - Wednesday, May 06, 2009 at 08:49
All reports suggest viewing
the lake from the air is the only worthwhile method - from the shore is underwhelming (dust, mud, mirages, flies and no birds - they are all out on the islands :-o).....
Check the regional tourism offices for LE tourist flights - seeing it is such a big deal, planes from centres way off will most probably be offereing a tour - on past observations, its not just
Marree, W
Creek etc that are into it.
363445
Reply By: wicket - Wednesday, May 06, 2009 at 10:34
Was there 2 weeks ago. You cannot see
water from either Level Post or Halligans. Best to get a flight from Maree and make sure you book early as there are plenty of people doing the same thing.
363460
Follow Up By: Member - Phil G (SA) - Wednesday, May 06, 2009 at 14:25
Wicket, were you at Halligans Bay?
Your info contradicts the photos and description given by Peter when he was there on 11th April.
Previous thread from 3 weeks ago.
631158
Follow Up By: wicket - Wednesday, May 06, 2009 at 16:01
We camped at Muloorina and then headed out to Level Post. Worked our way round to
William Creek and spoke to some people we had met at Muloorina who had driven out to Halligans to look at the
water and they told us there was none to be seen, also enquired at the pub who said the same. As we were short of time we didn't bother heading out there as it would just be a repeat of Level Post. This was the week after
easter. They all could have been lying though! Wrightair (?) indicated
water was about 8kms out from Halligans.
631170
Follow Up By: Pyro 1 - Wednesday, May 06, 2009 at 21:26
Wicket,
we to were there some 2 weeks ago (Halligans Bay) and we arrived at
the lake late in the afternoon. We walked about 200m and had about 2cm of
water lapping at our feet. We spoke to people who had visited that morning and the saw no
water it seems like the wind is moving the
water around.
631229
