Camp oven roast pork
Submitted: Saturday, May 09, 2009 at 15:44
Smokee
Hi, any tips out there for getting a good crackling on the pork loin that I'm doing in the backyard this evening? First time with pork and as you'd usually start off in a conventional oven with high heat just wondering if this is the way to go in the
camp oven. Lots of coals on top for the first 30 mins maybe? Ta in advance.
Reply By: Sir Kev & Darkie - Saturday, May 09, 2009 at 16:07
I'd use a fresh load of hot coals towards the end of the cooking to get Crackling.
I am not a big Crackling fan so don't usually bother.
Cheers Kev
| Russell Coight:
364016
Reply By: Member - Richard H (NSW) - Saturday, May 09, 2009 at 16:16
Score the top of the meat with a sharp knife, about 15mm apart and rub salt into the cuts.
You will then need to get heat to the top of the oven. This can be done by shovelling a few coals into the lid, but watch that you don't burn it.
Cook the meat pretty
well before you do the 'crackling' bit.
My wife can do this quite
well, and that's what I have done, under her supervision. Of course, we had a few disasters to start off, so don't be disappointed if things don't turn out.
All good dietary stuff, salt mixed with animal fat. Loverly!
I suggest you keep the house oven warm, just in case.
364020
Reply By: Sand Man (SA) - Saturday, May 09, 2009 at 16:22
Hope you haven't started yet Smokee:-)
Remove the rind from the pork and trim off the excess fat under the rind.
Place the rind flat and with a sharp knife, make incisions in the skin. Do not cut right through. (On some pork leg, loin or rolls, this may have been already done by the butcher)
Place the rind back on the pork and rub all over with oil, then sprinkle liberally with salt and rub
well so the oil/salt mix gets into the incisions.
With this method, half way through the cooking process, you can turn the meat over but keep the rind upward, or remove from the roast if it has crisped up.
Start roasting in a very hot
camp oven, where the heat beads, or coals, are placed on the top of the
camp oven only. After the rind has begun to blister and crisp up, you can remove some heat beads to reduce the temperature to moderate.
Roasting time for pork is around 1 hour per kilogram of pork, plus half an hour.
Happy Cooking!
Bill.
364022
Follow Up By: Smokee - Saturday, May 09, 2009 at 20:02
Hi Sand Man,
Yes, high heat first up worked
well , although what I did was leave the rind on, having rubbed in a bit of oil and salt of course. After about 30 mins sliced it off and draped over the pork. Whipped it out after another 10 mins and had as an entree! Put in the potatoes, added some halved and cored apples a while later and all were happy with the result. Next time will reduce the initial coals though, was so concerned about good heat for crackling, slightly overdone, mind you, still all consumed. I love my
camp oven.
631754
Reply By: Member - joc45 (WA) - Saturday, May 09, 2009 at 17:02
There was the guy who rang the Swine Flu Hotline, and all he got was crackling....
Seriously, if after doing all of the above, the rind hasn't crackled, you can remove it from the pork meat, wrap it loosely in paper towel and give it a few minutes on High in the microwave to expunge the fat, then leave it a few minutes to sit - it will come out soft, but it will crackle nicely after a few mins. Don't eat the paper towel.
Gerry
364026
Follow Up By: Bob of KAOS - Saturday, May 09, 2009 at 17:11
Joc
good one hah hah
631704
Follow Up By: Smokee - Saturday, May 09, 2009 at 20:19
Joc,
I recently had the flu and the standard response to friends was
" No, I haven't been kissing pigs".
My 'other half's' response was " you've been sleeping with one though"
631757
Reply By: landseka - Saturday, May 09, 2009 at 17:50
Another trick I use is that once I have scored the skin in a cros bleep ch pattern, I pour about a cup of boiling
water over the skin, it then opens up the score cuts nicely to rub the salt into.
Neil
364033
Reply By: greybeard - Saturday, May 09, 2009 at 20:18
high heat first for 30-40 mins.
i've tried rubbing the oil and salt in and just spraying lightly with oil an sprinkling salt on to the rind. the only difference i've found is the second method doesn't give you oily salt covered hands. the crackle works just as
well with either method. try it next time you
cook mr piggy :)
364071
