Low range in 100 series
Submitted: Monday, May 11, 2009 at 21:16
cobber
My 2005 LC 100 series has never been in Low Range, could there a problem in not using Low Range every now and then?
Reply By: Trekkie (Member - WA) - Monday, May 11, 2009 at 21:48
Someone who is better qualified than I am will give the correct answer. For me, I use
mine every few weeks just to be sure that when I NEED it I know it will work.
364394
Follow Up By: cobber - Tuesday, May 12, 2009 at 00:01
Thanks Trekkie, thats what I was starting to think..............use it or loose it.............lol
632099
Follow Up By: Rod, Sydney - Tuesday, May 12, 2009 at 09:01
Like Trekkie, I try and do a little preventative maintenance every now and then - use low range, run the winch, run the compressor, engage the lockers, run the shower, change the
water in the
water tank.
632115
Reply By: Member - Nick (TAS) - Tuesday, May 12, 2009 at 07:55
While I dont know of any problems it may cause the box, the engagement levers can become so stiff through lack of use that it can be impossible to select low range.Boots off and a good lube fixes it.
364423
Follow Up By: Horacehighroller - Tuesday, May 12, 2009 at 18:27
OK, I've got my boots off.
Where do I put the lube?
Oh Forgot. Socks off as
well?
632179
