Handiwash unit Kinetics Engineering Kent town SA
Submitted: Wednesday, May 13, 2009 at 19:14
ThreadID: 68794 Views:4545 Replies:3 FollowUps:3
I have a Handiwash in the canopy section of my Patrol
Vehicle ex Telstra with this little feature
The hot tap tho iust spins& for the life of me I can not seem to fix it. Pour the water in the reservoir & out she comes.Does anyone have one of these units & have had the same problem. Can anyone offer the solution to fix it.
Pretty handy unit if OK with 8 litres of water at 60 degrees
I have emailed Kinetics but so far no reply
Luv a frothy
Daz
Reply By: DIO - Thursday, May 14, 2009 at 09:12
Perhaps it's a 'push-pull' style tap !!
AnswerID: 364772
Follow Up By: Member - daz (SA) - Thursday, May 14, 2009 at 10:39
The tap is plastic Can see an O ring at the bottom
The tap body has a large thread
FollowupID: 632420
Reply By: Member - daz (SA) - Thursday, May 14, 2009 at 11:35
Problem solved.
Kinetics Engineering contacted me am.
Have now got the plastic tap body out of the unit
Nothing like an ordinary tap as it is plastic.
the outer case of the body had broken off at the base,& therefore stuck in unit
The edge of a screw driver at the point where it broke & a bit of pressure & we had enough movement to get it out
Kinetics can supply new tap body for $16.50 which to fit will take 30 seconds
The link to Kinetics shows the units which are very handy for supplying hot water for the weary traveller
http://www.thekineticsgroup.net/handiwash/gsa_
Daz
AnswerID: 364810
Follow Up By: mowing - Thursday, May 14, 2009 at 17:16
Hi Daz, As a side issue, how do you find the Patrol?
I am looking at one (ex Telstra) at the present and tossing up between that and a 03 RV Troopy (with high km).
On the face of it, it looks like if you can get a good one then they have a lot to offer.
Mark
FollowupID: 632481
Follow Up By: Member - daz (SA) - Thursday, May 14, 2009 at 20:17
ru a member
FollowupID: 632534
Reply By: Member - daz (SA) - Thursday, May 14, 2009 at 20:08
give me a call or email me from my profile with your number & I will ring you
There are a few available in SA at wholesale prices.
I found out who was driving mine in Telsta & gave him a call Pretty reassuring.
Have also spoken with the servicing dealers.
Daz
AnswerID: 364904
