Electric blanket
Submitted: Friday, May 15, 2009 at 11:08
cranswick
l was wondering how powerful an inverter would you need to use your electic blanket from a 12 volt power source are there 12 volt electric blankets you can buy? do they use up alot of electicity , could you have one on all night connected to your car without draining your car battery?
Reply By: Robin Miller - Friday, May 15, 2009 at 11:48
The smallest inverter - those can sized ones will work as blanket is around 50watt only.
Have seen 12v ones for cars.
They use about 4 amps , better to use a hot
water bottle.
365020
Follow Up By: Robin Miller - Friday, May 15, 2009 at 11:49
Forgot to add - they would flatten a normal car battery overnight
632660
Reply By: Mandrake - Friday, May 15, 2009 at 12:46
Was looking at one earlier on 4X4 site - 12 v - 2 heat stage runs at 45 W then drops to 20W ..
Would still drain your car battery !! Might be OK on a 100 ah or better - HWB is the go ! and a good furry blanket !
Rgds
Mandrake
365031
Reply By: Roughasguts - Friday, May 15, 2009 at 15:28
You could use a couple of hot
water bottles.
Then again maybe a Dog or two could keep you warm and have no battery problems in the morning.
Think the hot
water bottle would be a better option though.
365055
Reply By: Peter_n_Margaret - Friday, May 15, 2009 at 19:04
We use a normal 240V double electric blanket via an inverter.
It uses 60W (5A @ 12V) per side when flat out, and lower power consumption on LOW settings.
30 Minutes (5Ahr) is enough to get it warm before going to bed, and another hour or so in the wee hours on low (anothr 5Ahrs) if it is very cold.
OKA196 Motorhome
365092
