99 hilux 4x4 2.7 gearbox problems?
Submitted: Saturday, May 16, 2009 at 17:26
ThreadID: 68899 Views:5211 Replies:7 FollowUps:6
hi
have a unusual problem when dropping down from 3rd
to 2nd. feels like gear stick stuck. but doesn't do it
all the time. can hear a slight noise when clutch is engaged.
if you pump the pedal seems better.
Reply By: Louie the fly (SA) - Saturday, May 16, 2009 at 17:34
Could be syncro ring damage. Some Toyota gearboxes (& other brands for that matter) are quite problematic in this area.
Louie
AnswerID: 365261
Reply By: dustmike12 - Saturday, May 16, 2009 at 17:43
hi
had the complete gear box replaced 50,000km ago
AnswerID: 365262
Reply By: fatboy - Saturday, May 16, 2009 at 18:38
Hi Dustmike, have you recently changed the gear box oil , or is it quite old , all of the toyaota boxes i have owned have been very tempremental with oil viscocity
AnswerID: 365272
Reply By: mr fixit - Saturday, May 16, 2009 at 18:43
What do you mean "stuck" . . ..stuck in 3rd ???
or does it block and wont go into 2nd ??
AnswerID: 365273
Follow Up By: dustmike12 - Sunday, May 17, 2009 at 08:27
it locks in 3rd then you pump pedal to release to 2nd
FollowupID: 633041
Reply By: Member - ross m (WA) - Saturday, May 16, 2009 at 19:17
Pumping the pedal to make it better sounds like a clutch master cyl or slave cyl.
Or it could be the clutch is just about worn out.
Get the cheap fixes looked at 1st
AnswerID: 365278
Follow Up By: dustmike12 - Sunday, May 17, 2009 at 08:31
hi
would the clutch wear out in 50,000km
this happened after sky trek. hardly used the
clutch at that time but did feel different
after the course
FollowupID: 633042
Follow Up By: Member - ross m (WA) - Sunday, May 17, 2009 at 09:39
You must think we are mind readers
I dont know what sky trek is?? and you never told us it had a rebuild box 50000klms ago.
FollowupID: 633053
Reply By: wild dog - Sunday, May 17, 2009 at 09:20
Faulty detent on 3rd gear selector rail ?????????????
Is the noise audible every time clutch is engaged ???
AnswerID: 365348
Follow Up By: dustmike12 - Sunday, May 17, 2009 at 09:32
hi
yes a very slight noise.
so this means new gearbox?
FollowupID: 633052
Follow Up By: wild dog - Sunday, May 17, 2009 at 10:27
If there is a noise when the clutch pedal is depressed the most likely cause is the clutch release bearing.
I'd be taking it back to the firm that did the gearbox repair and get them to test drive it .
Dry input shaft splines ?? Was the spigot shaft bearing or bush replaced ??
FollowupID: 633060
Reply By: dustmike12 - Sunday, May 17, 2009 at 09:40
hi
who do reccommened in SA?
AnswerID: 365350
Follow Up By: mr fixit - Sunday, May 17, 2009 at 13:19
Old mate
You have a clutch problem.
When it "locks" in third does the clutch feel lighter or softer ?
FollowupID: 633072
