Nissan Patrol 4.2Lt Diesel Timing
Submitted: Monday, May 18, 2009 at 16:24
ThreadID: 68946 Views:17589 Replies:7 FollowUps:2
I have had two mechanics give me conflicting info
Does the Nissan GU patrol diesel have a replaceable timing belt or does it have a chain. One says chain which does not need replacing. other says belt which should be changed every 100 ,000K
Daz
Reply By: Member - John T (Tamworth NSW) - Monday, May 18, 2009 at 16:36
G'day Daz
I just had a quick look at the Patrol Forum - 4.2 has either chain or gears - not sure which but not a belt.
http://www.patrol4x4.com/forum/showthread.php?p=145230
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
AnswerID: 365512
Reply By: Member - Duncs - Monday, May 18, 2009 at 16:39
Daz,
My GQ had a chain, and with 160,000 trouble free k's under its wheels I can confidently say the GU is the same.
My advice to you is to find a mechanic you can trust. The guy who wants to dhange the belt is either ignorant or having a lend of you. Either way you don't want to let him anywhere near your car or your cheque book with a spanner.
Duncs
AnswerID: 365513
Follow Up By: kiwicol - Wednesday, May 20, 2009 at 17:48
The GQ has gears, and as they are the same motor in the GU, will be the same. Checked the work shop manual. Col
FollowupID: 633579
Reply By: Member - Phil R (Vic) - Monday, May 18, 2009 at 17:08
Daz
The 2.8l GU Timing belt.
The 3.0l GU Timing chain.
The 4.2l tdGu Timing gears.
I do not which one you have,the above is correct.
All the best.
phil
AnswerID: 365517
Reply By: Member - Malcolm (Townsville) - Monday, May 18, 2009 at 17:10
Daz
I just had a look in the Gregory's Manual - TD42 has GEARS.
When I rebuilt my ZD30 it had a CHAIN and gears.
Malcolm
living the 'good life'
AnswerID: 365518
Reply By: Member - daz (SA) - Monday, May 18, 2009 at 18:22
Thanks everyone.
The First mechanic I booked the vehicle to be serviced with told me he was Nissan trained & that it was a belt. ( & he would look after & service the vehicle) When I took it there he was away & one of the young fellows wanted to service it. Off I went looking for reliability.
Then took it to a local RAA approved mechanic who said "No belt do not touch". He has a patrol of his own.
Thanks for your info.
It gives me faith in the mechanic I have chosen.
AnswerID: 365536
Reply By: Luke SA - Tuesday, May 19, 2009 at 21:19
The TD42 definitely has gears and not a belt or chain. I had the timing cover off mine a few months back to fix an oil leak. The book also says so
Cheers Luke
AnswerID: 365741
Reply By: Travelling Pixie - Wednesday, May 20, 2009 at 13:52
Just out of curiosity, are timing gears as close to "maintenance free" as you can get for this part of a motor?
AnswerID: 365821
Follow Up By: get outmore - Thursday, May 21, 2009 at 00:19
only if they are metal gears.
holdens were notorius for using some sort of plastic or cardboard for there timing gears which were garanteed to leave you stranded
FollowupID: 633636
