Gq carby to efi
Submitted: Friday, Aug 29, 2003 at 09:34
Red Rover
Any done this conversion on the exsisting motor. Can get a manifold complete with throttle body, sensors etc. No computer, although i have the pirahna electronic ignition and have been told an aftermarket computer can run the
fuel independant from the ignition, in other words I don't need the factory efi dizzy and computer. I am aware I will have to run a high volume
fuel pump. Any thoughs on this?
Red Rover
Reply By: Truckster (Vic) - Friday, Aug 29, 2003 at 10:37
Reply By: Member - Allan - Saturday, Aug 30, 2003 at 00:30
Yeap can be done if you have manifold, injectors & throttle position sensor. My son converted his 2.4 L Bundera to EFI & it cost over $1000 even doing all the work himself. He had to replace the
fuel pump with one from a Commodore. He used a Haltec after-market computer. There is no preset program so you will have to 'map' the air -
fuel ratio yourself on a laptop and then have it checked on dyno & exhaust gas analyser.
Not a cheap exercise and you would have to really love the the GQ. It would not make it a better vehicle after the exercise but its a lot of fun if you like computers & electronics.Cheers
29615
