Air compressor
Submitted: Friday, May 22, 2009 at 12:35
ThreadID: 69068 Views:8609 Replies:12 FollowUps:5
Hi there Im looking at getting an air compressor to use in outback oz and wondered what I should look at getting and paying. Any tips would be welcome.
regards James
Reply By: Member - Fred B (NT) - Friday, May 22, 2009 at 12:49
Hi James,
you need to look at what you will be using it for... most likely use is tyres for 4x4, so a high volume compressor would be a priority. Do you want a portable or fixed in vehicle?
Most of the decent compressors are not that more expensive than the cheapies. You get what you pay for. Ensure you get a reinforced hose with it, not plastic. The plastic deteriorates quickly and subject to easy breakage especially in the tropics.
Hope this helps
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 366148
Follow Up By: Ozboc - Friday, May 22, 2009 at 19:42
Yeh , you get what you pay for .......
I bought a well known name brand compressor - paid good $$ - just lasted its warranty period then complete failure
Bought a cheap one of ebay 1/3 of the price -- 140 LPM lasted twice as long as the brand name one ( actually still going strong) -- gets used often especially in summer when its used to pump up MIN of 6 tires after being on the sand.....
so yeh you do get what you pay for
Boc
FollowupID: 633942
Reply By: troopyman - Friday, May 22, 2009 at 12:50
Just get one from ARB .
AnswerID: 366149
Follow Up By: Member - Ingo57 (NSW) - Friday, May 22, 2009 at 16:29
I agree with troopyman
I have the ARB in car and really happy with it.
Had bushranger before this....also gave me good service.
FollowupID: 633907
Reply By: vk1dx - Friday, May 22, 2009 at 13:10
If you are also only going to be using it on one car you may consider getting it mounted in the engine bay. If you do then make sure the hose is a good one (post above) and long enough.
An easy way of packing it hey!.
Ours is in the engine bay and my sons is in a box. He is mounting his in the engine bay before his next run.
Just my input.
AnswerID: 366161
Reply By: Crackles - Friday, May 22, 2009 at 13:12
Bushranger Maxair as a portable compressor.
ARB as a good compact unit. Casual use.
Boss 3 cfm compressor for pumping up oversized tyres, reseating beads. (continuous rated)
Endless air belt drive for running air tools etc.
Air-up for portable high speed inflation/competition.
Warn powerplant possibly the ultimate winch/compressor combo.
AnswerID: 366163
Reply By: Member - Redbakk (WA) - Friday, May 22, 2009 at 13:57
I have two...one is a high volume cheapy....and currently the second one of this type as the first died when it threw a leg out of bed....but I did not pay a lot for it and so it did not matter and was easy to replace.
I also have a air tank underneath as I have made this compressor a permanent fixture.Image Could Not Be Found
BUT my back up (which I carry all the time) is a blue tongue 30 lpm and will never let you down....this one I do recommend but there are so many to choose from...take your pick.
AnswerID: 366169
Reply By: Member - Tony & Julie (FNQ) - Friday, May 22, 2009 at 16:16
This is the one I use and it performs great
Kingcrome Air Compressor
Cheers Tony
AnswerID: 366197
Follow Up By: Member - Redbakk (WA) - Friday, May 22, 2009 at 16:58
Yep...that's the one I got in the back.
FollowupID: 633910
Reply By: RobAck - Friday, May 22, 2009 at 18:07
As many have said it really depends on how much you are going to use it ad for what. If you are a casual traveller and only air up and down occasionally then there are some good ones around the $200 mark. If you are a regular raiser and lowerer of tyres then you are now looking at around the $350-$400 mark.
We use a Big Red under bonnet and a Bushranger Supermax as a portable unit and both perform well albeit the Supermax is very quick. It also reseats a bead on a tyre where the Big Red really struggles
One of my trainers has just purchased the new ARB underbonnet or in a box compressor and it is brlliant. We back to back tested it against the Big Red startring from the same pressures and the same tyres and he was finished and packed away two minutes quicker than me. Very impressed and the price is excellent as well. Something better will always come along and we wear compressors out every three to four years so it will be interesting to see if anything is going to beat the ARB one in around a year's time
So again it all depends on your needs and the price you are prepared to pay. One of the 4WD magazines did a compressor test this year so search that out as well
RobA
AnswerID: 366218
Reply By: travelguy62 - Friday, May 22, 2009 at 18:08
imjame,
ARB units are reasonable and spare parts are available.I have had a nylon valve fail in one after a lot of use.I now carry spares and are easy to fit if it happens.
Cheers Guy
AnswerID: 366219
Reply By: rumpig - Friday, May 22, 2009 at 19:56
i've got a bushranger maxair II compressor, definately are good value when you pick them up at the 4wd show for $175. they retail for around $300 or just over i think.
have pumped up 2 fourbies and 2 caravans tyres one after the other several times after beach runs, so they can handle lots of continuos work without overheating.
AnswerID: 366245
Reply By: ABR - SIDEWINDER - Friday, May 22, 2009 at 23:44
Compressor Test Results here.
Compressor-Test
Derek from ABR
AnswerID: 366289
Follow Up By: ABR - SIDEWINDER - Friday, May 22, 2009 at 23:46
FollowupID: 633996
Follow Up By: ABR - SIDEWINDER - Friday, May 22, 2009 at 23:47
FollowupID: 633997
Reply By: Member - Matt & Julie (VIC) - Saturday, May 23, 2009 at 08:44
Hi James
I have a typhoon had it for a long time now has never let me down
Matt & Julie
AnswerID: 366300
Reply By: Member - Phil G (SA) - Saturday, May 23, 2009 at 21:28
Gday James,
I've got 3 compressors:
A 10 year old Blue Tongue 3 that has pumped up a million tyres without a hassle. Cost $380 in 1999/2000.
A Terrain tamer twin cylinder that has gone into my daughters LandCruiser that works slightly quicker than the Blue Tongue, and has a nice gauge in-line. Only cost $125 - show special 18months ago.
A very big Terrain Tamer (Series 3) that is supposed to pump up really quick. But it draws up to 45amps. I tested it today and an older cranking battery dropped to 11.8V when it was taking 5 minutes to pump a 285 tyre from 0-40psi. Then I tried the same again hooked up to the starting battery while the motor was running at 14.2V and it pumped the tyre in half the time. It cost $200 but came with rather cheap looking curly hose that isn't long enough to go around the vehicle. I'll get a new hose for it and supply it with enough electons via a decent hardwired cable.
AnswerID: 366397
