Delvac 5W-40 in a 1HZ
Submitted: Friday, May 22, 2009 at 20:05
happytravelers
Is there anyone using Delvac 5W-40 oil in a 1HZ. I've always used Delvac 15W-40 but have acquired some 5w-40 fully synthetic. Being an older design engine I was just curious if others were using it in this motor.
Regards Jon
Reply By: Member - Redfive - Saturday, May 23, 2009 at 16:21
Hi Jon
I use Penrite HPR diesel 15
HPR DIESEL 15
Bringing you the latest in light duty diesel oil technology, this semi-synthetic is suitable for most modern direct and indirect injection diesel engines including turbocharged. Ideal for new diesel vehicles under manufacturer’s warranty and normal driving conditions. Some vehicles may require Enviro+, HPR Diesel 5 or SIN 5.
SAE 15W-50, API CH-4/SL, ACEA A3/B4, M2C153F/G, Global DLD-1/3, VW 505.00
i changed to this after i Turbo it good stuff but im telling you your opened up a big can of worms on what oil to use
but what ever you use change it every 5000kms
Glenn...
366349
Reply By: PatrolSTL04 - Saturday, May 23, 2009 at 17:58
From what I understand, provided that the oil specifiications meets the requirements of your motor, the lower weight of 5 moves around the engine much better when cold (as opposed to a 15 weight.....less wear at startup with the lower weight), and when its warm the weight is 40. A chemist for Castrol told me this.
366365
Reply By: Member - Phil G (SA) - Saturday, May 23, 2009 at 20:58
Jon,
Theres a million people out there with 1Hz Toyotas and nobody with a 1Hz has answered your post. I expect that means (and I reckon its true) that no one would waste an expensive oil on an immensely reliable old motor. These thing don't wear out on standard oils, so no point in going to synthetics. If its anything like my daughters 1Hz, it goes black in no time after a change from all the soot. Would be a shame to see $100 worth of oil go dirty straight after a change. We use 15W40 diesel engine oils with out LandCruisers - have done for as long as I remember. Never worn one out.
366389
Follow Up By: get outmore - Sunday, May 24, 2009 at 04:21
Thats about it - I use 15-40 whatevers cheapest without going repco brand - but heck maybe that would be ok too
any way usually its shell or castrol about $45 for the 10 litres but i think it might have gone up
634139
Follow Up By: Member - Redfive - Sunday, May 24, 2009 at 14:49
Hi Jon
Forgot to say i have a 2002 troopy 1hz with a Denco Turbo on it
the Repco diesel oil is in fact
Mobil Delvax
Glenn
634191
