Oziexplorer - Speed issue
Submitted: Friday, May 22, 2009 at 20:38
Member - Si (WA)
Hey,
Got Oziexploer and all is working great. Positioning is spot on and update rate is really good with my EEE pc.
I have noticed that the speed is about half of what it should be though. I have looked through all the settings and everything appears to be set correctly based on the maps being used, gps type, config menu.
Anyone had a similar problem?
Simo
Reply By: Richard Kovac - Friday, May 22, 2009 at 20:44
Simo
What do you mean half of what it should be? 50 km/hr in stead of 100 km/hr?
Richard
366259
Follow Up By: Member - Si (WA) - Friday, May 22, 2009 at 20:54
yeah, there abouts. It is like it is showing nautical
miles. I am lead to believe this is the raw output (nautical
miles) from the GPS then the software converts it to km's. Don't know if this is 100% true.
It is not a major issue, just like to have everything set right if I can.
633960
Follow Up By: Richard Kovac - Friday, May 22, 2009 at 21:56
Simo
Try as below make sure the config is set up to read Km/hr.
If you have saved any tracks go to load. load track from file then open track control in view.
hi-lite track end open it you
well see all the recorded values the program is receiving.
Richard
Hopefully The Explorer Will answer your question soon.
633973
Follow Up By: Member - Si (WA) - Saturday, May 23, 2009 at 00:36
Richard,
every thing is definitely set to km/hr. I will check on the saved tack thing you mentioned.
Simon
634003
Reply By: GerryP - Friday, May 22, 2009 at 21:08
Hey Simo,
Under Configuration > Maps there is a Speed Unit setting. Check this is not set to MPH or Knots instead of KPH.
Gerry
366264
Follow Up By: Member - Si (WA) - Saturday, May 23, 2009 at 00:34
Garry,
I have checked all the settings and it seems ok. I had a look at the raw data from the GPS and the output seems to be in n/
miles but ozi should convert this to km's.
It is probably something simple but nothing is standing out.
634002
Reply By: Von Helga - Saturday, May 23, 2009 at 09:58
Surely the GPS has selectable settings as
well i.e. change it KPH
Trevor
366306
