ScanGuage2 question
Submitted: Sunday, May 31, 2009 at 08:48
ThreadID: 69355 Views:2752 Replies:2 FollowUps:8
I hvae a ScanGuage2 fitted to my Patrol. I have a question for the learned users of the group!
How do you get on when you do not fill the tank ? There appears to be no provision for partial fill only a "fillup" quantity.
This occurs when on a trip and I fill from gerry cans.
Reply By: Member -Pinko (NSW) - Sunday, May 31, 2009 at 09:57
Provided you have made adjustments ie the litres used on the scan gauge equal the bowser litres a few times they do eventually need no further adjustment as they become more accurate
But, when you fill from jerries you must fill the vehicle tank to the same level as you would from a bowser then do the fillup thing on the scangauge so it knows that the tank is full.
I can get about 100kms after the red light comes and I can run till a litre is left in the tank.
Hope this helps.
AnswerID: 367722
Follow Up By: Member - GeeTee (NT) - Monday, Jun 01, 2009 at 08:35
Thanks Pinko for your reply. Yep I understand all you have said but I was wanting to know if you could part fill the tank and enter the amount or you have to make a note of the quantity added and add that to the amount when you fill the tank and enter the total. It seems this is the only way to do it !
FollowupID: 635456
Reply By: KiwiAngler - Sunday, May 31, 2009 at 11:32
Can I ask what year, make model is your patrol?
I purchased a Scangauge11 unit about 2 years ago and cannot get it to 'talk' to the vehicle
Even though the Patrol has an OB11 compliant plug I have been told that Nissan has its' own 'language' and Scangauge doesnt recognise it
I have a 2004 Nissan Patrol Gu111
You have rekindled my interest :-))))))
AnswerID: 367739
Follow Up By: Member - Bentaxle - Sunday, May 31, 2009 at 11:41
I've a 2000 GU 3LTD and tried to get Scan GaugeII to run I couldn't get it to talk to my vehicle. The guys at ScanGauge agreed that there is a problem with the GU Patrols, apparantly it works overseas but GUs in Australia are talking in a different language as far as Scan Gauge is concerned, they gave me a full refund.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
FollowupID: 635364
Follow Up By: KiwiAngler - Sunday, May 31, 2009 at 12:00
Thats as I understand it too.
I tried for almost 6 months talking to all sorts of boffins all around the world to see if they could come up with some way of getting Scangauge to recognise the proprietory language that Nissan uses
So I wonder how the original poster got his to work??
FollowupID: 635370
Follow Up By: Patrol22 - Sunday, May 31, 2009 at 12:29
This failure to communicate between Scangauge and the Nissan must be limited to the Patrol...I have a Scangauge II fitted to my D40 Navara and it works perfectly.
FollowupID: 635374
Follow Up By: Member - Bentaxle - Sunday, May 31, 2009 at 16:14
Yes apparantly it is only the 3LTD GU that has this problem. The guys at ScanGauge at at a total loss as to why. It's a pity because it would a handy aid to have
Mike
FollowupID: 635391
Follow Up By: Member - Captain (WA) - Monday, Jun 01, 2009 at 00:44
The 2008 3.0GU Patrol works fine with the scanguage, my BIL has one on his vehicle.
Captain
FollowupID: 635440
Follow Up By: Member - GeeTee (NT) - Monday, Jun 01, 2009 at 08:28
Mine is a 2007 3 litre common rail turbo. It works fine with this unit , just "plug and play"
FollowupID: 635455
Follow Up By: Member - Bentaxle - Monday, Jun 01, 2009 at 11:03
I should have mentioned it earlier but it will work on the new 'common rail' motors but not the earlier engines
FollowupID: 635472
