Owners Manual - Electrolux 3 way fridge
Submitted: Sunday, May 31, 2009 at 12:35
Zebu
Hi All, Just got back into Caravaning after an absence of 10 odd years. Great to see this
forum is still alive and
well - and my same login works!
Any way, just picked up an 2001 Galaxy 16'6 van. It has an electrolux 3 way fridge (90 litre I think)
Anyone point me in the right direction for an owners manual. Cant see any model number on the front (or on the back). Seem to get it working ok - just be nice to no teh details about leveling etc etc.
any help appreciated.
Zane
Reply By: Member -Dodger - Sunday, May 31, 2009 at 15:05
For leveling you can get a round spirit bubble from most van
places and just place it in the bottom of the fridge to see if all is level .
As for a owners manual the ones supplied are next to useless and I do not know where you would get one.
Operation is simple ,
Turn it on when on 240v and set the thermostat switch at say 3 then see what the interior cabinet is at after 24hrs with the door fully closed then adjust switch up or down as required. This then should work for both Gas and 240v but not 12v as it is not connected to the thermostat as a rule.
Be aware that on 12v the fridge will use anything up to 12amp hr so it is advisable to run on 12v only when power can be sourced from a car that has the engine running. Usually these fridge's run better on gas than anything else.
367768
Reply By: Ianw - Sunday, May 31, 2009 at 18:55
I have the inst book for the Electrolux / Dometic RM 2330 fitted to my 2001 Supreme van, on my computer if thats any help.
Ian
367800
Follow Up By: Zebu - Monday, Jun 01, 2009 at 18:48
Ian, that would be great if you could email it to me at griffys@tpg.com.au
Managed to get it running on 240 and Gas and after making up a flu and deflector - I think its good for service.
Iif the manual has a wiring guide even better as im yet to sort out teh 12 volt side which hasnt been wired up (corredtly!)
Cheers Zane
635546
Follow Up By: Zebu - Thursday, Jun 04, 2009 at 07:54
Manual received - many thanks - same model as
mine!
much appreciated ;)
635911
Follow Up By: Ianw - Thursday, Jun 04, 2009 at 19:10
Is quality ok? Can probably do better if needed.
Ian
635987
