ScratchPro AP 60
Submitted: Tuesday, Jun 02, 2009 at 13:33
ThreadID: 69439 Views:2523 Replies:2 FollowUps:10
Has anyone used this product pls?
It's supposed to be painted on to the duco to provide a protective film as an anti scratching solution.
Once back to base it apparently strips off easily with pressurised water.
Sounds a good solution to polishing out the scratches as per my last trip.
Cheers. John.
Reply By: Peter McG (Member, Melbourne) - Tuesday, Jun 02, 2009 at 13:53
Hi John,
I use Autoskin
Easy to apply. 1l does 2 cars easily. Washes off in the carwash. Any hard to remove stuff comes off easily with Metho.
AnswerID: 368107
Follow Up By: Peter McG (Member, Melbourne) - Tuesday, Jun 02, 2009 at 13:54
Apologies.
The link is
Autoskin
FollowupID: 635679
Follow Up By: Peter McG (Member, Melbourne) - Tuesday, Jun 02, 2009 at 13:55
For some strange reason the Autoskin link doesn't work so here's the address:
www.autoskin.com.au
FollowupID: 635680
Follow Up By: Lex M (Brisbane) - Tuesday, Jun 02, 2009 at 17:08
link
FollowupID: 635692
Follow Up By: Member - John Baas (WA) - Tuesday, Jun 02, 2009 at 20:23
Many thks guys. JB.
FollowupID: 635715
Follow Up By: Member - John Baas (WA) - Tuesday, Jun 02, 2009 at 21:45
Hi Peter, re Bentaxle's comment below re attracting dust; does Autoskin have the same disadvantage pls? Cheers. JB.
FollowupID: 635738
Follow Up By: Peter McG (Member, Melbourne) - Tuesday, Jun 02, 2009 at 22:46
Yes it does but this all comes off when you hose it down. Not an issue really.
FollowupID: 635748
Reply By: Member - Bentaxle - Tuesday, Jun 02, 2009 at 15:49
I've used it frequently and it really does the job, apply 2 coats with paint roller allowing about 30min between coats at least 2 days before trip. Do not get it on plastic or rubber extremely hard to remove from them. I just apply to sidepanel and guards on vehicle. After trip hose vehicle down and it will peel off.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 368117
Follow Up By: Member - John Baas (WA) - Tuesday, Jun 02, 2009 at 20:24
Thks Mike, how does it go in rain, esp if you're travelling at any speed pls? John.
FollowupID: 635716
Follow Up By: Member - Bentaxle - Tuesday, Jun 02, 2009 at 21:04
I've used when its been raining and at speed and the effect is weird. When it's applied it dries clear though it has an 'orange peel' appearance but when its really wet it turns white and when you are driving it bubbles, and you have these large bubbles moving about on the side panels. I've never had it come off on these conditions even in heavy rain ,but I would have been travelling no faster than 80-90km/h. The only other thing is that it attracts dust like a magnet.
Mike
FollowupID: 635727
Follow Up By: CJ - Wednesday, Jun 03, 2009 at 17:17
Thinking of applying some to my side panels just before the Cape York trip, but can someone please advise if or how it handles river crossings (planning to do the OTL)
FollowupID: 635821
Follow Up By: Member - Bentaxle - Wednesday, Jun 03, 2009 at 19:19
I'm not sure but if it is allowed to dry out between crossings Ithink it should be ok, I first saw it used on Range Rover on a very wet weekend down Sth WA, we had rain and numerous creek crossings and it held up.
Mike
FollowupID: 635870
