mulga park rd
Submitted: Thursday, Jun 04, 2009 at 10:37
ThreadID: 69496 Views:3245 Replies:3 FollowUps:8
has anyone travelled mulga park rd around to mt conner lateley is the rd suitable for xtrail towing camper trailer
Reply By: Member - Stephen L (Clare SA) - Thursday, Jun 04, 2009 at 14:09
Providing that the road is not wet, it is a great road to drive. It has all types of driving, from sandy sections, to gravel. The sand sections are no problems at all.
Drop your tyre pressures as you do for any dirt road and keep your speed down and you will have no worries.
StephenImage Could Not Be FoundImage Could Not Be Found
AnswerID: 368385
Follow Up By: dthomas - Friday, Jun 05, 2009 at 06:29
thanks for the info last time i travelled it was 22 yrs ago and from what i remember i did not use 4wd . do you know what condition th ernest giles rd is in as i thought after going to kings canyon i may go that way to alice
FollowupID: 636060
Follow Up By: Member - Stephen L (Clare SA) - Friday, Jun 05, 2009 at 07:51
The Ernest Giles Road is a different kettle of fish. Firstly there are signs advising no caravans and it is a lot more corrugated and the sand is deeper and is a slower track to drive. Your vehicle would be able to handle it, but you may damage your van. It all comes down to the way you drive and your driving experience. For me it was just another sandy track, but we had to pass a couple of small groups that were sitting on 30 kilometres per hour because of the sandy conditions.
FollowupID: 636065
Follow Up By: dthomas - Friday, Jun 05, 2009 at 08:04
Stephen we will be towing a trak shak camper trailer if you think the vehicle will handle it i think camper should . do the sandy patches require low 4wd or will hi 4wd do it as xtrail doesn't have low gear (one down fall of the xtrail which is a pity as its a good small 4wd) also what tyre pressure did you run at cheers
David
FollowupID: 636068
Follow Up By: Member - Stephen L (Clare SA) - Friday, Jun 05, 2009 at 08:28
Hi David,
The sand is thick in patches, and we were in two wheel drive, and was not in the situation to even thinking of low range,let alone going into 4Hi, as traction was not an issue. If you work on dropping your tyre pressure about 20% and the van even a little lower. On the Prado, I was running 24psi front and 26psi at the rear. Like I said above, the vehicles that we had to pass most likely thought that the road was very bad, but for us, it was just another sandy track that required more attention to driving conditions.
FollowupID: 636071
Follow Up By: Motherhen - Friday, Jun 05, 2009 at 13:51
We chose not to go through the Ernest Giles Road as someone had fun and games taking their Bushtracker through the sand, but it was fine to access Henbury Meteor Craters from the Stuart Highway end. As it was, we went to Kings Canyon via the Mereenie Loop after touring the West Macs and going to Palm Valley (recently added Blog), then on to Uluru so didn't need the Ernest Giles road.
Mh
FollowupID: 636111
Reply By: Richard W (NSW) - Thursday, Jun 04, 2009 at 18:20
Did it 3 weeks ago towing a camper trailer, not the one in my vehicle photo. Road was in pretty good nick and you should be OK if you drive to conditions. As said may challenge the Xtrail if wet.
AnswerID: 368417
Follow Up By: dthomas - Friday, Jun 05, 2009 at 06:33
Richard thanks for that . you didn't by chance do the Ernest giles rd as well ? or know what condition its in or suitability for xtrail cheers david
FollowupID: 636061
Follow Up By: Richard W (NSW) - Saturday, Jun 06, 2009 at 06:04
David,
No I did not do this track.
Regards Richard
FollowupID: 636198
Reply By: Motherhen - Thursday, Jun 04, 2009 at 23:59
You cannot access Mt Connor as it is on private property. The station conduct tours to the mount. You can get fairly good views from the road.
AnswerID: 368475
Follow Up By: dthomas - Friday, Jun 05, 2009 at 06:37
thanks Motherhen for advice I knew we couldn't access MT CONNOR without doing tour just thought it would be a better alternative drive to the rock rather than doing the bitumen thing ,cheers David
FollowupID: 636062
