Gearbox Oil Change Frequency
Submitted: Friday, Jun 05, 2009 at 00:26
gonzstort
I have a 95 Troopie, what is the opinion out there on how often I should change the gearbox oil. I only average about 5000K a year. So I am wondering if my oil changes should be time or kilometer based.
Reply By: donk - Friday, Jun 05, 2009 at 01:13
I would go 40,000 klms or 2 years whichever comes first assuming you are not going through deep
water
I think the servce intervals for the later 70 series such as yours is actually more than this (i will check tomorrow)
Regards Don
368478
Reply By: Member - Doug T (NT) - Friday, Jun 05, 2009 at 01:39
My 94 model has oil changes every 100,000 Ks , and each time Diff's , G/Box, T/Case , is changed I add the product as depicted in all ,
Image Could Not Be Found
368481
Reply By: obee1212 - Friday, Jun 05, 2009 at 09:03
I do it with the forty thou recommended service except I do that at 50000. the difs and gearbox/transfer dont take a lot of oil so it not expensive and small price to pay for peace of mind. If you have LSD dif it definitely needs changes. I use the recommended oil and I dont believe additives help the formula.
Change the brake and clutch fluid too. Brake fkuid absorbs
water from the atmosphere and will cost you plenty as I have learned to my own loss.
Owen
368506
Reply By: get outmore - Friday, Jun 05, 2009 at 10:22
I guess the best suggestion is to do more travelling in it
I do 12 -15k a year and do those oils every 2 years.
they can collect
water and shavings off of cogs so it probabally is worth doing them evry 2 years or so in your case
368519
